Old 04-23-2012, 12:12 PM
Loyd981 Loyd981 is offline
Default Eleven Rack as audio interface only
Hello:
I have question. How do I set-up the eleven rack as just audio interface. I would like to use amplitube 3 in standlone mode to mess around with some settings in amplitube.
Any help would be great.
Thanks
Loyd981
Old 04-23-2012, 01:54 PM
nst7 nst7 is offline
Default Re: Eleven Rack as audio interface only
Assuming you've installed the driver, when you open Amplitube standalone, you will have the choice to select the 11R as your interface (as opposed to built in output, etc.).
I think it's under preferences, or one of those upper left pull down menu choices.
Eleven Rack as Interface Dopamine macOS 10 02-02-2013 11:35 PM
Eleven rack with another interface ? oplatner Eleven Rack 11 05-30-2012 07:33 AM
Eleven Rack as the primary audio interface? Voyager42 Eleven Rack 1 05-29-2011 12:29 PM
Pro tools LE plus Eleven Rack. Audio Interface required? needled39 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-15-2010 05:27 PM
Eleven Rack + Another interface? Kaigne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-01-2009 06:49 PM
