  #21
Old 04-21-2012, 12:01 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Finding fizz and removing it with EQ
True-Z can make a difference, but with Active pickups, all settings sound pretty much the same - except 1M, which sounds the best to me on MOST amps/Rigs when using active pickups. Other wise I just leave True-Z on Auto, which usually defaults to 230k, at least for me because I use a Green screamer on a majority of rigs, without a DIST box ON, the Auto setting for me is usually 1M + Cap.
The exact Auto setting depends on what is ON in your signal chain at a given time and how it is structured.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
  #22
Old 04-21-2012, 01:45 PM
Benoni's Avatar
Originally Posted by dbvoyager View Post
hey benoni,
I was actually done with the topic so I saw your reply way too late, sorry.
and about the fizz, I guess I'm sort of figuring out how to cut out disturbing frequencies and I too actually noticed there is always fizz in the sound, even in the commercial records just as you said.
I think I'm now more accurate with parametric EQ than before, so I think I'm getting better results.
I'll put here a test record which is only 20 secs long, so you can listen to and give me further advices(if you care to )
http://soundcloud.com/dnbilgili/4-1 [gp6 drums ]
that sounds fine to me.
if you still have the rig setting, record another pass but don't dial out the fizz
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
The fizz that wasn't really there Deny Eleven Rack 2 08-13-2011 02:58 PM
Weird fizz making sound when Re-Amping JustGoWithIt Eleven Rack 6 08-03-2011 07:11 AM
11r Standalone XLR Noise/fizz, hum fly_with_v Eleven Rack 4 12-13-2010 10:04 AM
getting rid of fizz/noise SloeGin Eleven Rack 3 11-14-2010 02:00 AM
fault finding by removing plug-ins... AdamPT8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-17-2010 11:03 AM
