Old 06-24-2003, 06:58 PM
regis regis is offline
Default best way to archive/backup projects?
I have been using DVD-R to backup all of my projects. THat has been going fine, but recently I had to retrieve a PT session and files and the mac said my DVD was damaged. I was HOSED! The DVD was lovingly stored and had no visible scratches or anything of that sort. I also verified after the burn, which was a few months back. The only thing I did that may have contributed to the problem was put a label on it (the basic paper kind).
I am now doubting this method for archival, so I'd like to know if any of you have other recommendations. I am leaning toward firewire tape backup. Thoughts?
thanks!
cs
Christopher Stevens
producer/writer/mixer
Fabmusic/CS Productions
Nashville, TN
www.fabmusic.com
Old 06-24-2003, 07:03 PM
Default Re: best way to archive/backup projects?
Whatever method you use.. unless you back up at least in duplicate.. you haven't backed up at all.
I personally use Retrospect and DDS4.. and always make an A and B backup set.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 06-24-2003, 07:07 PM
Kurtstudio Kurtstudio is offline
AIT 2, AIT 3 but it's $ very $ is the standard, but many use DDS 4, all work great, most perople use either mezzo or retrospec to back up, both can be bought in a firewire config but SCSI is the faster domain. Unless you have USB2 or Firewire 800. can you say G 5 With the price of firwire IDE drives it is a very inexpincive way to back up files. Buy a 120 gig and partition it into 2 60 and drag and drop. Good Luck [img]images/icons/cool.gif[/img]
Later, Kurt
[email protected]
Intel duel Quad core
PT 8.0cs3
HD4
D Command / D control
Old 06-24-2003, 07:20 PM
yeah, I should have mentioned that I do a retrospect nightly to firewire drives, so I have short-term backup solved. But anything more than a few months back is archived. I'm thinking the firewire approach is the way to go, because, as you state, they are quite cheap now. I'll look into DDS though.
Thanks for the tips dudes!
cs
Christopher Stevens
Nashville, TN
www.fabmusic.com
Old 06-24-2003, 09:34 PM
Tubelover Tubelover is offline
DVD-R is fine for backup, but unless you verify it in either Retrospect or Toast, and do a duplicate, the media can be anything and fail.
Old 06-24-2003, 10:08 PM
Kenny Gioia Kenny Gioia is offline
I would continue backing up to your DVD and also get a pair of 100Gig Firewire drives.
When you fill them up, buy 2 more.
Bring the DVD's one of the firewire drives home with you so they are stored in different places.
Buy an extra internal drive and backup there too.
Old 06-24-2003, 11:08 PM
well, I've got either really good news or really bad news, depending on the final outcome. I have checked a bunch of my DVD backups and they either won't mount at all, or are extremely sluggish with many errors. Many of these backups I verified. I really think it's a case of a failing superdrive at this point.
thanks again for your ideas.
cs
Christopher Stevens
Nashville, TN
www.fabmusic.com
Old 06-26-2003, 12:10 AM
When burning DVDs with Toast, don't choose DVD. Burn it as if you were making a CD. This will result in faster restore times when you need to restore. Perhaps your discs aren't hosed but its taking forever to read the UDF file system?
And whoever said that you don't have a backup unless you have two copies is correct. If you only have one copy, its an archive.
Does a Backup Archive Drive have to be 64Mb cache? Jimibrix Windows 1 09-11-2011 07:37 PM
How to Archive projects porkipine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-16-2006 11:38 AM
how do you backup your projects Matt Chan Post - Surround - Video 14 08-16-2005 07:01 PM
Backup and Archiving Projects markgr82nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-11-2001 01:05 AM
Backup and Archiving Projects nqmike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-10-2001 12:21 AM
