Old 12-11-2010, 04:21 AM
GTBannah GTBannah is offline
Default Pro Tools Aggregate I/O
Hello, folk,
I have the DIGI 002 connected and, in the play back engine menu, I have four options:- DIGI 0002, built in output, built in input and Pro Tools Aggregate I/O.
I understand all but number four. There seems to be no operational difference between number one and number four.
Any ideas?
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 12-11-2010, 08:30 AM
lincol1 lincol1 is offline
Default Re: Pro Tools Aggregate I/O
your "fourth" option refers to PT9's ability to allow the user to set up an aggregate device (made up of any the available core audio devices you choose.) Your digi rack cannot be used in the aggregate device set up, so unless you have a 3rd party core audio interface, you pt aggregate I/O would be made up of any of the built in mac I/O.
Lincoln Mitchell
www.studiofifty.net
Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia
RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue
Old 03-14-2011, 12:13 PM
MikeSchles36 MikeSchles36 is offline
Sorry, you lost me there...sounds like this allows me to set up a group out somehow and output to multiple places at once with the aggregate I/O. How far off am I?
Thanks
Old 03-14-2011, 12:21 PM
.... but using third party CoreAudio interfaces, you're saying ....
Interesting! DIGI-AVID is opening the options up!
Derrkins
GuyBarTola
Old 03-14-2011, 12:29 PM
Dism Dism is offline
Thanks
Not just a group out, but allows you to combine interfaces up to the allotted 32 I/O. This is an OSX feature that PT9 takes advantage of.
As mentioned before, it is not supported with the 002/003 family, or any HD hardware.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 04-05-2011, 09:58 PM
djmoss djmoss is offline
My problem is that my prior 003 I/O settings have defaulted to the Aggregate I/O and I can't seem to change them back. I hit default but it doesn't give me active 003 I/O (ie 4 x stereo analoge INs, etc).
Ant suggestions?
Old 04-05-2011, 10:04 PM
Avid's Avatar
Avid Avid is offline
Administrator
Try the first group of instructions in Kbase 381131 and choose the 003 as your playback engine.
Administrator
Old 04-11-2011, 10:19 PM
jj5000 jj5000 is offline
When I installed PT9 I found my fasttrack pro doing odd things so I switched over to the pt aggregate in the IO settings and things were less odd, but working better.
Then I discovered that PT 9 had installed the eleven rack driver in the system preferences. After deleting that things went back to normal.
Clumsy, but it worked out for me...
Old 04-27-2011, 02:42 AM
Is there anyway of disabling the Aggregate I/O default. I find I have to do a work around every time I open PT9 using my 003R. Basically PT9 defaults to Aggregate I/0 each time and I have to hold down 'N' when booting, select 003, etc. This does not always work mind you...
How can I have the default I/O as the 003 as it was with PT8LE?
Cheers
Old 04-28-2011, 08:26 AM
cdavis6406 cdavis6406 is offline
yea go into the audio prefs for osx then select Protools Aggregate and delete it. If you want it back jus create a new one.
Oh yea and make sure that the 003 isnt selected as the default audio device for osx. If it is Protools will always choose something else.
Mac Pro, Snow PT 10HD,Sequoia, Reaper
W7/64, PT 9HD,Sequoia, Reaper
192 HD, HD-N, 002C BLA,
BLA AGB,Autuer,Lucid,
MicroCLock, Pultec, UA, Sebatron, Focusrite, Trident,API, A-Designs, Purple Audio
003 and Pro Tools Aggregate I/O TimR Pro Tools 11 4 04-29-2013 02:36 PM
Pro Tools Aggregate I/O ggkarman macOS 24 09-10-2012 01:01 AM
What is Pro Tools Aggregate? sixstrings22 macOS 1 10-21-2011 03:00 PM
Aggregate device trouble Snow Lep! Tascam US122 won't aggregate? crizdee Pro Tools 9 3 12-02-2010 03:17 PM
Pro-tools Aggregate I\O? CLASS-A-DUDI TAMIR Pro Tools 9 0 11-27-2010 12:03 AM
