7.4 midi timing problems
Currently loving 7.4 but has anyone else noticed serious timing problems with the midi clocking in RTAS instruments? Say i use Guru or Reason rewired, the timing is all over the place! Even on a very simple pattern a (say a 16th arp repeat) it is extremely sloppy/inconsistent/unuseable.
This also happens in TDM plugs like McDSP's Synth One (arpeggiator) Is this a bug we need to wait to get sorted or is it just me?! Digi? Lifer
Win 7 Pro 64 PT 10 HD, HD4 Accel Jetway JNAF92-Q67 Intel 2700k 3.8ghz 16GB Crucial Ram |
Re: 7.4 midi timing problems
have you tried selecting an input on your instrument track ie 1-2 or any other input 3-4 etc.?
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
This sounds very similar to a problem I've been having using ProTools LE v 7.3.1 (not yet tried 7.4). Playing back anything midi was totally erratic and unuseable.
I came across the blog pasted in below called "Midi is Jumbled" describing a similar problem which suggests a Windows Hotfix for Dual Core 2 Duo processors : http://duc.digidesign.com/showflat.p...1217816&Forum=,c6,&Words=midi&Searchpage=1&Limit=25&Main=1217816 &Search=true&where=sub&Name=&daterange=1&newerval= 1&newertype=w&olderval=&oldertype=&bodyprev=#Post1 217816 (cutting and pasting the above text should take you there) I installed the XP patch suggested by spkGuitar and it now all seems to work !! Hope this helps. |
MIDI Timing PT 7.4 LE - Anyone having problems? | Donkey Kong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 117 | 10-08-2008 06:03 PM |
MIDI Timing PT 7.4 LE - Anyone having problems? | cheekypaul | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-24-2008 08:08 PM |
MIDI Timing problems with PT7.3 ?? | humbuzz | MIDI | 1 | 05-15-2007 10:53 PM |
Midi timing problems | poolhouse | Pro Tools TDM Systems (Mac) | 2 | 08-12-2006 04:20 AM |
MIDI Timing Problems | e-rase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-16-2006 07:20 PM |
