Help with Behringer ADA8000 for more inputs
I'm thinking about purchasing the Behringer ADA8000to expand my 001's inputs up to 16. My computer right now has no problem recording 8 tracks at a time. My question is: how much of an impact will the 8 additional tracks put on my processor? Is there a chance that my computer won't be able to handle that extra work? Thanks!
www.earlydemise.com |
Re: Help with Behringer ADA8000 for more inputs
Hard to answer that question with any certainty without knowing exactly what your computer setup is. Generally, you shouldn't have any problem.
Dell Dimension
Pentium 4 2.66GHz 2 GB RAM
you can do a test - using the same principle as the davec test - get the 'show system performance' window open - set up 16 tracks and drop them in to record (the fact that you are recording silence is of little relevance) then let them run for what you think would be the duration of a normal song - if your CPU meter is OK it's all OK
cheers, scott
"...I asked you not to tell me that!" |
really?! I had no idea. I thought the silence would be a factor...
If you want to test this with sound, make all 16 tracks set to mic line 1, and while recording talk into your sm57. let it go for a few minutes then stop it and see if you can play back. btw the ada8000 is a very good piece of equipment for the price.
www.DIGITAL859.com |
considering a 250mHz beige G3 can cop the full 64 tracks on an internal IDE drive (using TDM of course), i reckon you'll be right.
I recently purchased the ada,...
this weekend I wanna connect and test it... any advice for settings in pro tools?? do I have have to adjust some settings, or will it just plug and play?? thnx in advance...
Asus A4KA-Q003H AMD Ath 64 3200+ 1024MB WD Scorpio 60GB 2.5" PATA 5400 8MB davec 32+15 www.surely.nl |
Should be exactly the same as this. I use it with a g4 powerbook(1.5 ghz, 512 ram) and a 002, and I've recorded several concerts using all 16 channels and it's been nothing but great.
check out this thread
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Behringer ADA8000? | sethbrand | General Discussion | 3 | 02-20-2007 11:58 PM |
Behringer ADA8000 | kevinsimons | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-18-2006 12:06 AM |
Behringer ADA8000 | stevesound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 05-31-2004 01:40 PM |
Behringer ada8000 | hotstuff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-21-2003 07:01 PM |
Behringer ADA8000 | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 10-17-2003 04:00 AM |
