Driver Conflict ProFire 2626 and Project Mix
Hi:
I primarily use my Project Mix to track most things, but I have acquired 2 Profire 2626's so I can track drums and percussion over 16 tracks. BUT there is a driver conflict. I can't have both Project Mix and ProFire 2626 drivers installed without losing the Project Mix. I really don't want to have to swap out drivers every time I record on the ProFire's - Has this issue been resolved yet? Thanks Danny |
Re: Driver Conflict ProFire 2626 and Project Mix
Pro Tools LE/M-Powered supports only one Interface and up to 18 I/Os as far as I know. You can use the driver for your Project Mix and connect one ProFire using the Adat I/O, or instead use the Profire driver and connect the two Profire units via Adat. Both setups get you 16 I/Os, additional 2 if using the first S/PDIF of the setup with a separate preamp with digital out for example.
If you would like to switch between the drivers I would suggest making a copy of your system to another partition so you have two separate os-installations with the two different drivers. You will have to select the driver/installation at boot time and reboot if you want to switch, but at least it saves you from reinstalling drivers everytime you want to change your setup... Quote:
[Macbook Pro 15" C2D, Pro Tools 9.0.5, M-Audio Profire 2626, Terratec EWS Mic8] - [Mac Pro Quad-Nehalem, Pro Tools M-Powered 9.0.5, M-Audio Firewire Solo, M-Audio Oxygen 49] |
ProFire 2626 driver update | clausiii | macOS | 2 | 11-29-2012 05:07 PM |
Profire 2626, Project Mix I/O, PT9 | protools123 | macOS | 5 | 09-25-2011 11:57 AM |
ProFire Lightbridge / Project Mix IO / Pro Fire 2626 | doppler58 | Pro Tools M-Powered (Mac) | 4 | 09-02-2010 11:49 AM |
Profire 2626 driver issues - (not compatible with xp or 7?) | adm1lk | Pro Tools M-Powered (Win) | 1 | 07-15-2010 04:04 PM |
Bootcamp driver test for Profire 2626... help please? | theaero | Pro Tools M-Powered (Win) | 0 | 07-02-2008 01:03 PM |
