#381
Re: Pro Tools 12.3 - more info
i changed the wording in my post above ...
#382
Anymore ideas?? or is an update needed? |
#383
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII |
#384
Finding PT12.3 to be very unstable and starting to make me look bad in sessions. Anytime I get deep in editing audio, MIDI, etc it will no doubt crash. Tried a fresh drive, an old drive, and 10.9.5 and 10.11.5. With no luck..
May have to move back to PT11 for a bit, but that would be so sad, as "commit" is my favorite thing on earth.. This is the crash I am getting about 10 times a day.. 2015-12-05 17:48:30.838 Pro Tools[1556:507] invalid drawable Sys_MachExceptionHandlerGlue.cpp catch_exception_raise::1 2015-12-05 17:50:00.064 Crash Reporter[1684:507] Unknown class LengthLimitingTextView in Interface Builder file at path /Applications/Pro Tools.app/Contents/Frameworks/Crash Reporter.app/Contents/Resources/Breakpad.nib. |
#385
Hi BTW
I am a d-command user. Have you notice that in 12.3.1 the susp groups switch doesn't work anymore? Anybody has something like this happening? Last edited by Watagushu2013; 12-07-2015 at 04:24 PM. |
#386
It works fine here. I would try to trash PT preferences. If that doesn't work, try to un-declare/declare the console in the Peripherals page.
Studio rig - Pro Tools|HDX 2018.7 | Logic Pro X.4.2 | Avid HD I/O (8x8x8) | 6-core 3.33 Westmere w/24GB RAM | OS 10.12.3 | D-Command ES | Eleven Rack | Vienna Ensemble Pro 5 Mobile rig - Macbook Pro i7 w/16GB RAM | UA Apollo 8p | Pro Tools|HD 2018.3 | Logic Pro X.4.2 | OS 10.12.6 Last edited by Stig Eliassen; 12-08-2015 at 12:23 AM. Reason: typo |
#387
Thank you Stig.
I'll try that. I been using my backup preference file for a long time now, using PT preferences app. If my pt erase the preferences (it does that a lot I think for using 10HD & 12 HD on the same system) Then I restore my backup preferences and rapidly I can get to work again because the preferences contain all the D-Command configuration. So I thing is time to begin in zero to re configure a clean trash of preferences. |
#388
It was the preference file!
I just re configure the d command settings. Thanks again Stig. |
#389
Cool. Glad I could help.
#390
I have been trying to move slower when editing/zooming and this is causing a couple less crashes. I actually am always saving right before moving or clip gaining to be safe.
But I really start to see crashes when "Nudging" "Clip Gaining" "Grabing Regions". So is this is something with using hard drives ? Or since I have a 10gb disk buffer the audio should live in my RAM. So is this a Memory issue?? I will try going back to the "normal" setting in disk cache and see if this helps. |
Curious about info required, a way to obtain info in mail bo | andre67 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-21-2007 01:34 PM |
More info on the new Pro Tools!!!!! WOW! ;) | vocalvoodoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-25-2005 11:44 AM |
Pro Tools 6.0 Info | The Central Scrutinizer | Pro Tools TDM Systems (Mac) | 0 | 01-31-2003 10:20 AM |
Pro Tools 6.0 info | EarnestBliss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-13-2002 09:29 PM |
