Old 06-19-2016, 10:05 AM
Soliloquay Soliloquay is offline
Default 002 Firewire Cable
It looks like the firewire cable for the 002 no longer works. I know this because I used an old glyph firewire cable which powered it fine when the computer kept telling me it can't locate my hardware while using the cable that came with it. Also the little green light in the back next to the fire input remains unlighted when I use the fire wire cord that came with the 002. The firewire that came with the 002 is a lot thinner than that of the glyph so I am skeptical that i could continue to use it or just any other firewire cable. Does anyone know if i could just buy any fire wire cord and use it with the 002? I don't use the 002 regularly and just need to to check something in it this morning when it kept giving me the message unable to locate...no matter how many times I rebooted the MAC mini
Thanks
Soliloquay
Old 06-19-2016, 10:55 AM
Default Re: 002 Firewire Cable
Firewire cables can be surprisingly problematic. If you suspect the one in the 002 I would just throw it out and buy another one, I can't stand having suspect cables around. make sure it is the cable not just the fact that you reseated a cable in the connectors. Any decent brand Firewire cable is probably OK. Be really careful not to hot plug these connections on a 002, you can fry the Firewire chip.
Old 06-27-2016, 08:50 AM
The sometimish cord started working again.
Soliloquay
Old 06-27-2016, 04:18 PM
That's an even better reason to throw it away and right away. Hot-patching the FW connection can(and usually will) fry the FW circuit in the 002(or 003) and can also take out the FW chip in the computer(learned the hard way), and an intermittent connection is about the same as pulling and reconnecting. Always(as in ALWAYS) have the computer and the 002/003 powered OFF when touching the firewire cable
Old 06-28-2016, 03:19 PM
VRW VRW is offline
Originally Posted by albee1952 View Post
ALWAYShave the computer and the 002/003 powered OFF when touching the firewire cable
+100
And get a new FW cable, it´s worth the few bucks.
FW400 to FW400
https://www.amazon.com/Male-Clear-Fi...wire+400+cable
FW400 to FW800
https://www.amazon.com/Clear-IEEE-13...MD1CZEXSS2#Ask
FireWire 400-to-FireWire 800 Cable w/iMac Danny Pro Tools 11 16 06-19-2016 08:23 PM
Need A Firewire Cable. philip888 General Discussion 2 04-18-2013 11:00 AM
Firewire cable? Jono_G 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 01-29-2010 11:04 AM
switching from USB cable to Firewire cable moonwalker2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-02-2009 08:21 AM
Bad Firewire Cable... Dogcode 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-11-2006 06:20 PM
