Old 02-05-2018, 01:32 PM
idris idris is offline
Default Disable snap selection to grid
Is there any way to disable the snap selection to grid funciton?
ie When using the Selector Tool (or the Smart Tool equivalent) if you hold CMD (Mac) and select a portion of a clip with the cursor, the selection boundary snaps to the next grid value.
I don't remember being pestered by this function until sometime around PT12.???. Now I find it a complete PITA.
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 30yrs experience in pro-audio - mostly for picture.
Old 02-05-2018, 02:34 PM
kalony kalony is offline
Default Re: Disable snap selection to grid
dont you just habe to select „slip“ instead of „grid“ in the upper left corner?
Gesendet von iPhone mit Tapatalk
Old 02-05-2018, 03:01 PM
For the workflow in question I'm using Shuffle more.
The snap only occirs when CMD is pressed in conjunction with a mouse drag.
Old 02-05-2018, 03:09 PM
hmm, sorry, i am still not sure what you want to know.
in shuffle modus „snap to grid“ should be disabled by default.
i dont even know, if you can enable it with pressing cmd as you can do it in slip mode for example.
Old 02-05-2018, 03:21 PM
It's not the positioning of the clip that snaps to the grid, but rather the boundary of the selection you are trying to make.
Try this :
Choose Shuffle mode
Set Grid to 1sec
Zoom in on the time line until you have about 5sec visible.
Using the Smart Tool, select about half a second.
Then try to make the same selection whilst holding down CMD.
The second time the out point of the selection, will snap to the mext whole second.
Old 02-06-2018, 07:05 AM
Originally Posted by idris View Post
...ie When using the Selector Tool (or the Smart Tool equivalent) if you hold CMD (Mac) and select a portion of a clip with the cursor, the selection boundary snaps to the next grid value...
I don't understand; why are you holding the cmd key down while editing if you don't want the function it provides? Why not just release the cmd key?
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-07-2018, 03:36 AM
I'm not intentionally doing it.
After making a selection I am using Paste To Fill, which uses CMD. Because I have an Apple Magic Mouse, unless I move my index finger well clear of the surface of the mouse, PT recognises it as CMD/select.
I'm trying ot get out of the habbit of leaving my finger on the surface of the mouse (after 30yrs of mouse use it's quite a habbit to break), but it would be a whole lot easier just to diable the function.
That's the Why.
I take it there are no suggestions as to How?
Old 03-22-2018, 04:07 AM
Ffab Ffab is offline
Same problem here! Have you found a solution?
The only workaround i`ve found is to set grid to samples and then choose 1 sample...
Old 03-26-2018, 12:35 PM
My best work around is to slow down.
I wondered whether it's something loosely to do with using a Magic Mouse and the surface thnking you're scrolling when you're not, but haven't got round to digging out something more primitive.
Old 10-24-2018, 10:53 PM
scottmckay scottmckay is offline
This absolutely hit the nail on the head for me.
I feel like I literally have to edit in slow motion now that this behavior is mandatory.
Since command always meant slip mode, with one finger I could both ensure my edits would slip (regardless of mode) and at the same time already have half of the next key command pressed, say, for the next tool I was going to switch to, all WHILE I was drawing a selection or trimming a region. It was a great workflow that really let me fly thru a dense editing session.
Not so anymore.
Now I have to stop and make sure I release my click before hitting the command key. This wastes time now that I have to add this waiting phase to the workflow. It really adds up when you have a few thousand edits to perform over the course of a session.
Default behavior? Fine! But all I want for Christmas is a cute little checkbox that lets me disable this behavior so I can get back to editing efficiently.
Snap to grid Neurosis Pro Tools 12 4 05-26-2016 05:15 AM
Edit Mode difference between: Grid and Slip+Snap to Grid zenstone macOS 0 02-05-2015 04:34 AM
Snap-To-Grid How johnny41 Pro Tools SE and Essential (Win) 6 09-21-2013 01:42 AM
Grid BUG - PT fails to snap to grid when zoomed out 25ghosts Pro Tools TDM Systems (Mac) 0 04-18-2009 07:54 AM
6.4.1 Grid Mode often does not snap to grid???? Philthy Pro Tools TDM Systems (Mac) 4 05-24-2005 03:25 PM
