Plugin to route audio out to bus
Are there any plugins that can route audio out to a certain bus?
I would like to insert sends between other plugins on a track. AVID Pro Multiband Splitter, for example, can send parts of the spectrum to different outputs, and Melda MCompare is capable of listening to different instances, so it should be doable.
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60 macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4 |
Re: Plugin to route audio out to bus
NUGEN SigMod and NUGEN Audio Receive.
In SigMod, Crossover module if you want to split by frequency or Tap module if you just want to send over (parallel). Audio Receive sits on the other track to receive the audio sent. You can demo SigMod to see if this works to do what you want (Audio Receive comes with it)
How to route USB audio into Pro Tools | Armando | Pro Tools TDM Systems (Mac) | 8 | 06-12-2018 07:43 PM |
Looking for a plugin to route pro tools audio to desktop audio? | pearlxzildjian | macOS | 2 | 03-21-2017 02:18 AM |
Route Mac audio into Protools | HDXSound | Pro Tools 12 | 6 | 12-21-2015 11:24 PM |
Plugin Route folders (DAE) | Songbandit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-22-2004 07:55 AM |
Can't route CPU audio thru I/O! | mrdecibel | Pro Tools TDM Systems (Mac) | 2 | 05-28-2004 05:04 PM |
