os10.3.5 (error code -36) when copying files to dv
Has anyone seen this and have some insight? Mac os 10.3.5 getting an (error code -36) when copying files to a dvdr for backup?
My studio: http://www.logcabinmusic.com |
Re: os10.3.5 (error code -36) when copying files to dv
You mean copying FROM a DVD-R?
Or are you talking about burning a DVD? -36 from the finder is usually a read/write error. Happens when drives fail or the media is unreadable. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Copying to a DVDr is when I get the error... I've also had it when copying between external firewire drives, and even from the internal to external drives. I can still open the sessions in ProTools no problem... I can't seem to narrow it down to a specific drive... CompUSA techs had it for four days, and did a 'soft' reinstall of the OS... They said the computer passed the mac authorized tests, whatever that is... I'm at a loss right now...
I also got the error message when opening a session from the same drive as the os... played fine, but it the task window was searching for 2 missing fade files... I closed the session and in the task window it said something to the effect of 'rendering fade files (error -36)...
How do you "copy" to a DVRr?
You can burn a DVD using Toast or the finder. When does the error occur? While the DVD-r is being burnt? frank.
Try this: Close the session. delete the fade-files folder of that session. Empty trash. Open the session and have PT re-create all fades.
Or alternatively just don´t burn the fades to the DVD. It´s a waste of space and PT can easily re-create them anyway. I never burn fades to backups. Sames spave in large sessions. frank.
Actually before the burn... Using the finder... dragging files onto the dvdr icon...
My system has been rock solid for a while... something is breaking down I suppose. The only other type of research on the -36 error has to do with a drive being too full... I have recently been using a new external firewire (lacie D2) ... 250G... 2 partitions... one is about full right now... just a few meg available... Is it possible that that jumbled something else? I can't believe (yet) that it's the external drives though (unless it triggered something else) because I've had the errors when no externals are connected... I'm going to connect my externals to another mac and do some backups/tests... just to be sure the data is not really screwed (and it's not an external firewire issue)... Can't imagine that the files are corrupt since I can still open up the sessions no problem.. Thanks!
Unfortunately it is certain audio files that it hangs on when doing the actual copy to the dvd...
The fade file situation just came up last night after I got the computer back from the shop... I opened up a session that I had on my OS drive, just to see what would happen (before connecting any external drives). Hung up the whole system when the message came up (ProTools wouldn't quit) and I had to do a hard reboot. I had a secondary internal hard drive that I unplugged at that point... the OS rebooted ok, and I had a session so I plugged some externals and cautiously went to work. I thought at that point that maybe that other internal drive was the culprit. At the end of the session I backed up my files to multiple externals, and then, went to copy some files to a blank dvd... error code -36 ... again...
-36 error is usually the first sign of a dying lacie drive. First you get read/write error then the drive becomes slower and slower when copying then it dies. I had 4 die like that. frank.
Apparently it was main drive (os) that took a dump... Thank god for the exact clone I made a few months back. Booting to the clone has kept me working. Thanks!
Error Code -50 When copying to Firewire HD | derF | Pro Tools TDM Systems (Mac) | 4 | 04-25-2018 12:36 AM |
Help with copying ALL PT sessions and files... | bhuber77 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-10-2010 12:19 PM |
os10.3+SCSI64kit+PT6.2.3+copy files to=CRASH! | poldo | Pro Tools TDM Systems (Mac) | 12 | 05-26-2004 07:18 AM |
Need Help! Code error in 6.1 (XP) when compacting audio files | X-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-20-2003 11:54 AM |
Copying Regions between files | blackelmo | Digidesign Hardware & Software | 3 | 07-21-1998 07:09 AM |
