How do I sync my Digi001 system to my Digi 003 System?
I would like to sync my Digi001 as a slave for my Digi003 system. What should I do? Would I have to connect the Digi001 PCI Card to the PC? I would like to do it via ADAT, because I'd like to have a total of 16 channels (8-001, 8-003). How to configure the clock settings? Thanks |
Re: How do I sync my Digi001 system to my Digi 003 System?
I think to get them in sync from a TRANSPORT standpoint, you could do it via MIDI. I was able to sync Pro Tools with my old SAW PRO program that way, and it was frame-accurate every time. We are talking two separate computers here, right? Pro Tools will only "see" one interface at a time.
it will not work like you think it will. the protools interfaces do not support a "standalone" mode like you are wanting. you can only use one interface at a time.
you need to purchase an 8 channel preamp with with adat out. |
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Putting some thought to this, to be able to pull this off on one computer, the only front end app that has a good shot of seeing both hardware boxes would be Reaper. If that's the case you could use Reaper for tracking and PT for everything else. A better solution I myself would do is to track down a second hand Alesis AI3 or something similar to give you your extra 8 I/O on your 003. Shane
a behringer 8 channel preamp with adat out is only $200. seriously, its that easy. if you want to go a bit better, the presonus d8 is $400. better still, an octopre or digimax for around $1000. that not enough? you got the crane song spider for $8000. you get the idea.
thanks to you all for your help...
what I am asking for is: how to connect both of them in one computer so I can get the 16 I/O... I think it is not possible... |
that is what i told you from the beginning. |
You're right, it is not possible. Pro Tools is designed to see only ONE interface at a time. If you want to access the ADAT optical i/o there's quite a few ways to do it. The Behringer ADA-8000 does a fine job, or look u p two posts. Time for some Ebay browsing!!!!!
Shane
How do I sync my MBox 2 system to my Digi 001 System | ER-NYC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-05-2009 10:54 AM |
BEST System For Digi001?? | depeche_cerati | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-14-2007 10:54 AM |
Can I use A digi001 with a TDM system ? | lg | Pro Tools TDM Systems (Mac) | 3 | 06-29-2002 12:39 AM |
digi001 and new PC system | Dr.Octavo | General Discussion | 1 | 02-15-2002 01:07 PM |
System OK for Digi001? Help | lyricon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 03-16-2001 07:09 PM |
