Old 04-21-2018, 12:59 PM
johnescalera johnescalera is offline
Default protools le "8.05" crashes windows update
S.O.S.
Protools le "8.05" crashes my computer after windows did the update described below...
Any suggestions or insight on this???
Update for Windows 7 (KB2952664)
Installation date: ‎4/‎14/‎2018 1:17 PM
Installation status: Successful
Update type: Important
Install this update to resolve issues in Windows. For a complete listing of the issues that are included in this update, see the associated Microsoft Knowledge Base article for more information. After you install this item, you may have to restart your computer.
More information:
http://support.microsoft.com/kb/2952664
Help and Support:
Old 04-21-2018, 03:08 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: protools le "8.05" crashes windows update
Trash prefs and try again
Daniel
Old 04-21-2018, 03:18 PM
Please elaborate. I'm not sure what you mean by trash prefs
Old 04-21-2018, 05:35 PM
YYR123's Avatar
https://www.sweetwater.com/sweetcare...s-preferences/
I also assume that these have been done
https://www.sweetwater.com/sweetcare...-optimization/
Daniel
Old 04-22-2018, 01:21 PM
Thank you for the information... Fyi. I ended up un-installing, then re-installing Protools. It still crashed. I for some reason decided to right-click on the shortcut on my desktop, then selected run as Administrator... It started Protools & I was then able to re-validate the installation...
Problem solved...
I don't understand why or how Windows update managed to corrupt only Protools but thanks allot Microsoft...
Thank you again for your input Sir.
Old 04-24-2018, 09:07 AM
Starting with Windows 7, its been a standard recommendation to install using the Run as Admin option, and also to set PT to always Run as Admin. There is some question regarding the current versions of PT, but 8/9/10 all are subject to this
"No Update" showing instead of "Current" in Application Manager jsbach Pro Tools 12 1 01-16-2016 03:54 AM
002 rack "clicks" and Windows beeps when "Setting Up Midi" or sw0mgt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-03-2012 03:42 PM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
AV Option 5.3.1 update DOES NOT WORK!!! With ProTools 5.3.1 - "Aborting Init" Samhein Pro Tools TDM Systems (Mac) 4 06-27-2002 07:43 PM
