"Problem detected with audio clock" - Pro Tools 8.0.4, M-Audio Fasttrack Ultra
System info:
Windows 7 x64 Pro Tools M-Powered 8.0.4 (latest) M-Audio Fasttrack Ultra interface with drivers: 5.10.0.5099 (latest) What caused the problem: I recently installed Pro Tools M-Powered 8, and I believe the default version after the install was 8.0.1. I was happily recording along. Then, I realized I hadn't updated to the newest version. So the ONLY thing I did was update Pro Tools to the latest version of 8.0.4. Then happened this problem... Problem: Every time I start up Pro Tools now (even a blank project) and hit play, I get this error: "Problem detected with audio clock. Check that your clock source and sample rate are correct." So I did check. My M-Audio control panel reads: 44.1kHz sample rate, internal clock, and 1024 samples buffer. My Pro Tools Session -> Setup reads: 44.1kHz sample rate, 24-bit depth, and "See Control Panel" for clock source. Any idea what's going on? |
Re: "Problem detected with audio clock" - Pro Tools 8.0.4, M-Audio Fasttrack Ultra
SOLVED...
I installed the 8.0.4cs2 update I found in the stickies in this forum, which I couldn't seem to find on the main website, and the problem is fixed. |
"Problem detected with audio clock. Check audio clock and sample rate." Focusrite 2i4 | Terry Wetzel | Third Party Interfaces | 10 | 11-08-2013 06:18 AM |
Please help - "Problem detected with audio clock" error on HP laptop | NickPt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-28-2011 05:49 PM |
"problem detected with audio clock" error | turbodude | Pro Tools M-Powered (Win) | 0 | 03-10-2011 01:01 PM |
"Problem with audio clock detected." error; Pro Tools won't start playback | wintersdark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-04-2010 06:23 PM |
"Problem detected with audio clock" on brand new installation | Katzi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-18-2010 12:10 PM |
