Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 07-19-2020, 05:15 PM
Muziqjonez Muziqjonez is offline
Default Pro Tools 12.3.1, Win10 Pro and Digi 003
Can someone please help because I am at a loss! I upgraded from my Win7 pro computer that ran the Mpowered ProjectMix with ProTools 8.1 to ProTools 12.3.1 and since I needed an interface I got a Digi 003 Console But Pro Tools keeps saying I need to add a HUI. I tried adding the legacy drivers but to know avail! The sliders move when the 003 is recognized by me holding down the “N” button! Tried to do a firmware update but it stops at “LOADING”... and Vegas mode worked. Not sure what to do now or which legacy drivers to use ... can someone, anyone please help!
SPECS:
3.40GHz Core i7-2600K Sandy Bridge QUAD-CORE Accelerated Processor (3.80GHz Max Turbo)
20GB DDR3 RAM
1TB SSD
HDMI Video Port
DVI Video Port
VGA Video Port
Optical S/PDIF Out
Internal Fans
775W Power Supply
(6) Rear USB 3.0 and 2.0 Ports
(2) Front USB 2.0 Ports
FireWire Port (IEEE 1394 6-Pin)
THX High Definition 8-Channel Audio
Onboard Ethernet LAN
Windows 10 Professional Operating System (64bit)
ProTools HD 12
Old 08-06-2020, 09:41 AM
Default Re: Pro Tools 12.3.1, Win10 Pro and Digi 003
This may be a tough one to solve. First off, are you able to get audio into Pro Tools and hear playback with the 003?
#1-Are you positive the 003 works? Hot-patching the firewire can easily fry the FW chip in the 003 and the repair cost is more than the unit is worth now.
#2-The firewire driver; there are usually 3 drivers available in Windows. Legacy is 1(and Avid recommends this driver, but it never worked for me). TI Compliant is another(and this is the driver that worked for me when I had my 003). I don't remember the name of the 3rd driver, but when I tried it, it turned my 003 into a midi note generator(seriously, if I had EZdrummer in the session, the PLAY button would trigger the hihat sound)
#3-you may be pushing the boundaries of compatibility between Win10, that version of PT and the old(and unsupported) 003.
If you ARE getting audio in and out with the 003(it is the selected Audio Engine in Setup>Hardware), then the 003 is probably okay, but HUI is not going to help(if you added a HUI device in the Peripherals menu, remove it).
Do try the firmware update again but next time, once it starts, go eat lunch or watch a movie. It can take from 20-30 minutes to hours(I don't remember, but it may also be dependent on internet speed).
By all means, do try the other firewire drivers(knowing what FW controller you have might help. That info would appear in a sisoft Sandra report). You may also end up needing to get another interface, in which case I would NOT recommend 002, 003, mBox(any version) or any M-Audio product. Stick with newer products(Focusrite, Presonus, RME, etc)
Old 07-07-2021, 10:40 AM
APM APM is offline
I would recommend you to use the latest version of PT and the 003 drivers on W10, it should work fine
Old 07-07-2021, 01:20 PM
This is where the 003 drivers get downloaded from. Ever since PT9, the driver for the 003 must be downloaded and installed separately from the Pro Tools software(in the old M-Powered and LE versions, the driver was part of the PT installer).
https://avid.secure.force.com/pkb/ar...02-003-Drivers
Make sure you download for the controller and not the rack as the drivers are different.
PT2019.5 and Win10 senghor Pro Tools 2019 2 05-11-2019 08:50 AM
Pro Tools 12 on Win10 and C24 Camilo Toledo ICON & C|24 5 02-22-2017 02:03 PM
Repeatable Bug? 12.5.1/Win10 YYR123 Windows 3 12-28-2016 02:35 PM
Xpand2 UI Corrupted in Win10 cubdukat Pro Tools | Intro Discussion 1 07-03-2016 06:34 AM
Pro Tools 10 & Komplete 8 Can't load plugins [Win10] Oglon3r Virtual Instruments 3 04-19-2016 06:43 PM
