Old 07-27-2009, 03:28 PM
stevegalante stevegalante is offline
Default Re: Procontrol blinking, breaking, switching, not working...
Originally Posted by elicious View Post
sorry, tough day... (see mj thread)
buy 2, they're cheap...
it's funny, i think they normally deal with orders in the hundreds and then i call looking for my pair...
they won't even take my money up front,
they want p.o.'s with letterheads and 30 day billing and such... comedy
b.o.l.
e
elicious, exactly which model ? I will be ordering two from Canada (so 110-120V).
Thanks !
http://www.stevegalante.com
Old 07-27-2009, 08:20 PM
Craig F Craig F is offline
Do they send a T1000 after you if you don't pay?
Thank you,
Craig
Old 08-04-2009, 12:41 PM
michael c michael c is offline
Check for bad solder joints around the power supply before actually replacing the PS. This was the problem with ours and Audio Rehab in Burbank fixed it..
Old 08-18-2009, 01:43 AM
11miles 11miles is offline
Does anybody perhaps know which PS exactly to get for the Procontrol?
http://www.skynetusa.com/index.php?p...on=com_phpshop
...me failing english? That's Unpossible
_____________________________________
Old 08-18-2009, 11:37 AM
blackmacdaddy blackmacdaddy is offline
11 miles, I don't know the right one, BUT, if you clean all the pins on the power supply (male & female) with a $10 can on CAIG de-oxit & some elbow grease with q-tips or some such, you may 'get 'er working' just fine.
I have personally repaired a half dozen Digi 002s doing just that. Fortunately, my ProControl & fader pack have never had the "oxidizing power harness problem." YMMV Best :) Walt
It's only R'n'R but I like it.
  #16
Old 08-19-2009, 07:23 AM
Bookerv12 Bookerv12 is offline
It's actually the plug pins on the circuit board have to be re-soldered.
Then the female plug has to be replaced.
That will fix it for good.
Burnishing the pins just puts the failure off for a while.
You don't need a new PS.
Good luck
bookerv12
  #17
Old 10-15-2009, 02:59 AM
Cryos's Avatar
Cryos Cryos is offline
Mine too, just started a few days ago! I noticed it starting with the scribble pad one day, it had miscellanious writting for a split second but never gave it a second thought until today! Now I'm having the exact same issue full blown, it's periodic and annoying. I also hear a Relay Clicking In and out as it happens
just where the control room section is, and when it does happen depending on the sequence my surround monitoring kicks in and out.
I hope all it is, is the power supply and not a whole mother board issue!
We have an authorized digi service center here, I'll bring the unit in next week and see what they have to say.
I'm sending the service center a link to this post.
At least when I take the unit off line but leave it on the controlroom section still works!
Thanks for the post!
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
  #18
Old 10-25-2009, 10:50 AM
deafguy deafguy is offline
Seriously folks, you can fix this yourself.
I'm not a tech and there may be other PS issues...BUT
When mine went wacky, I bought a pair of magnifying reading glasses, and found tiny fractures in the solder joints at the pin connectors.
Just re-solder the the pin connectors on the PS assembly.
It'll take you longer to open remove all the little screws and open the PC up than it will to heat up an iron and do the fix.
Get in there!
cheers
DG
  #19
Old 02-19-2010, 03:07 PM
Hi Cory, did you have your PC repaired here at CEV (I presume...) ? How did it go ? Was it the P.S. ? Thanks (I have one here too freaking out ...)
  #20
Old 08-14-2011, 02:17 PM
granieri granieri is offline
Thanks for mentioning me Michael C.
My company is Audio Rehab, Inc. in Burbank, CA.
I'm at your service for any pro audio electronic repairs.
I've fixed hundreds of ProControls.
...hopeful to one day become an Avid warranty service center.
Status light blinking outputs not working HELP!!! tlamb VENUE Live Sound Systems 1 10-21-2007 08:44 AM
PEC/DIR switching on ProControl? Branko Post - Surround - Video 14 09-10-2006 06:46 PM
PEC/DIR switching on ProControl? Branko ProControl, Control|24, Command|8 1 09-07-2006 02:03 PM
procontrol not working with pt. 6 wallygrant ProControl, Control|24, Command|8 4 06-04-2003 11:33 PM
Procontrol not working w/new G4 Seller ProControl, Control|24, Command|8 0 02-23-2001 09:36 PM
