Ethernet connection diagram?
Hi. I had my D-Command Main Unit and Fader Units hooked up for the past four years... to an older (2010) Mac Pro tower. I disconnected the ethernet cables to do some minor trouble shooting. I guess I should have labeled my wires... because I can't get Pro Tools to sense BOTH units at the same time. It's always one or the other. Does anyone have a fool proof way of describing the best way to hook up these units? A cabling diagram? I've been using a ethernet hub, to allow me to have a wired internet connection as well. I can get the internet and the main unit working... or I can get the fader unit and the internet to work... but I can't seem to get BOTH units working. If I have the internet and the main unit on the hub (using Ethernet port 1), I figured I could plug the fader unit into Ethernet port 2. But when I let Pro Tools scan a port, it then forgets the other port exists. And vice versa. Was I supposed to plug BOTH units into the hub? or just one? Guesses anyone? Or wiring diagrams?
Re: Ethernet connection diagram?
Try to connect both units to the hub using standard cables (no crossover), and also use a standard cable from the hub to the Mac.
I have mine plugged into it's dedicated router after running into some conflict in the past with the internet connections
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1 - D-command 24- Trinnov Dmon6 |
I am trying to get a C|24 to talk on a second ethernet port, but can only select the first ethernet port in the setup dropdown list. Is there another config I need to change to use a second Ethernet port?
Thanks in advance |
Ethernet Connection Not Working (Mac>PC Slave) | rogercollege | Pro Tools 12 | 4 | 10-26-2016 06:22 PM |
Procontrol ethernet connection problems | alanc | ProControl, Control|24, Command|8 | 2 | 05-31-2015 03:52 PM |
C/24 ethernet connection | jmtayloraudio | ICON & C|24 | 3 | 04-23-2010 10:06 AM |
No Ethernet Connection? | Mark McCabe | ICON & C|24 | 0 | 09-25-2003 11:44 AM |
control 24 and ethernet connection | ianmiller | ICON & C|24 | 3 | 03-02-2002 11:24 AM |
