Re: PT 12.8.2 errorcode
Try starting PT with the N key held down until the popup window comes up, there choose the interface you have and see if that helps.
Really? Worked like a charm for me- Close ProTools- Then go to that page- When you go to that page, click on the "AAE Prefs 11+" box on the right, third one down. Then when you re-open PT, it should scan all the effects and rebuild the list that was corrupted. Good Luck!
Still this same problem. When i hold N i get another massage PT app has quit unexpectedly. I don't know what's wrong???
I'm getting errorcodes.... and also keystrokes are not always registering, I need to quit PT to get them to work. Keys D F G (ones I use all the time) are sometimes working sometimes not.
The error codes occur if I sometimes drag a clip whilst constraining its movemnt with the WIN key. Throws up an error, then most commands throw up more errors. Its a repeatable bug on my machine. Trashed prefs etc, still the same 12.8.2 is buggy as hell, seems like they didnt bother testing it, cummon avid. I'm on a Win10 machine running 12.8.2HD |
http://duc.avid.com/showthread.php?t=300050
#16
I found this possible solution in a different thread:
If that still does not work, you will need to reset the Pro Tools Aggregate I/O over at the Audio MIDI Setup (under "Applications/Utilities": 1. In the Finder, click Go > Utilities 2. Double-click on Audio MIDI Setup 3. Click Pro Tools Aggregate I/O 4. Click the (-) button at the lower left of the window to remove the aggregate device 5. Relaunch Pro Tools Good luck! |
#17
very helpful, thank you - that did the trick
#18
Make sure that if you update in the future, I ALWAYS trash old prefs before I update and I also uninstall the previous HD driver, if you are on Hardware. That seems to keep me out of these kinds of trouble. G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel DanteHeadphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
#19
Pro Tools 12.8.2 - Assertion Line 822
Hey guys,
i need urgent help!!! PT doesn΄t start. And I΄ve got no idea why it doesn't. When I try to start, I get the following message: Could not complete your request because Assertion in "/Volumes/Development/212377/ProTools/AAE/Source/AAX/CFicAAXWidget.cpp", line 822. Anyone out there, who can help me??? |
#20
Re: Pro Tools 12.8.2 - Assertion Line 822
Hi, welcome to the community.
Have you tried to re-install your PT and trash preferences?
logic6 errorcode 28519 from core audio treiber | g-nius | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-02-2004 03:13 PM |
Athlon XP2000+ plus A7N266-E = errorcode -6004? | Mark_Knecht | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-29-2002 12:21 AM |
ERRORCODE: -7058 ????? | cisco677 | Digidesign Hardware & Software | 0 | 12-17-2000 04:21 PM |
Errorcode: FE8-d-0013 | Eugene | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-15-2000 08:19 AM |
