Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 03-01-2018, 04:20 PM
TOM@METRO's Avatar
Default Re: Error message "hardware in use by another application"
And again, as stated earlier, be sure you have turned off all system sounds if they are using the same hardware that you are using for Pro Tools.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-06-2018, 12:49 PM
Naom-Harv's Avatar
Naom-Harv Naom-Harv is offline
Thanks for the advice folks. I don't think I can afford to upgrade my gear at the moment (at least not until I try out this free version of Pro Tools to see if I can learn it well enough - maybe if it becomes a big part of life I'll upgrade my wee studio! So hopefully I should be able to cope with the setup I have, at least long enough to get started. Will post system info in my next post below.
Old 03-06-2018, 12:56 PM
Naom-Harv's Avatar
Info as required on 'Help us help you' page:
Computer Model: HP Pavilion 17-G001NA M3Z14EA
Processor: i3-5010U
Processor Speed: 2.10 GHz
OS Version: Windows 8.1
Avid Hardware: n/a
Pro Tools Version: First 2018.1
Amount of memory installed: 8 GB RAM
Attached peripherals: Focusrite Scarlett 2i2 - USB device. Connected to 'SS' USB port
Number & type of drives installed: None (none additional to laptop's own drives)
Old 03-06-2018, 01:12 PM
Naom-Harv's Avatar
SiSoftware Sandra
ID
Host Name : Studiolaptop
Workgroup : WORKGROUP
Computer
Model : HP Pavilion Notebook 103C_5335KV G=N L=CON B=HP S=PAV X=Null
Serial Number : 5CD52*****
Chassis : HP Notebook
Mainboard : HP 8094
Serial Number : PFEAN02*******
BIOS : Insyde F.21 06/05/2015
Intel vPro : 10.0.30.1060
Total Memory : 8GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz (2C 4T 2.1GHz, 2.1GHz IMC, 2x 256kB L2, 3MB L3)
Socket/Slot : FC BGA1168
Chipset
Memory Controller : HP Core (Broadwell-ULV) Host Bridge 100MHz, 8GB DDR3 SO-DIMM 1.6GHz 64-bit, Integrated Graphics
Memory Module(s)
Memory Module : Micron 16KTF1G64HZ-1G6E1 8GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6)
Video System
Monitor/Panel : SDC Generic PnP Monitor (1600x1200, 17.1")
Video Adapter : Intel(R) HD Graphics 5500 (24CU 192SP SM5.1 900MHz, 768kB L2, 3GB DDR3 1.6GHz 64-bit, Integrated Graphics)
Graphics Processor
OpenCL : Intel(R) HD Graphics 5500 (192SP 24C 900MHz, 2MB L2, 3GB DDR3 1.6GHz 64-bit, Integrated Graphics)
D3D 11 : Intel(R) HD Graphics 5500 (192SP 24C 900MHz, 768kB L2, 3.8GB DDR3 1.6GHz 64-bit, Integrated Graphics)
OpenGL : Intel(R) HD Graphics 5500 (192SP 24C 900MHz, 768kB L2, 128MB DDR3 1.6GHz 64-bit, Integrated Graphics)
Storage Devices
Seagate ST1000LM024 HN-M101MBB (1TB, SATA600, 2.5", 5400rpm, 16MB Cache) : 932GB (C:) (D:)
hp DVDRW SU208GB (573.5MB, SATA150, DVD+-RW, CD-RW) : 547MB (E:)
Logical Storage Devices
Windows (C:) : 908GB (NTFS, 4kB) @ Seagate ST1000LM024 HN-M101MBB (1TB, SATA600, 2.5", 5400rpm, 16MB Cache)
RECOVERY (D:) : 23GB (NTFS, 4kB) @ Seagate ST1000LM024 HN-M101MBB (1TB, SATA600, 2.5", 5400rpm, 16MB Cache)
WINRE : 650MB (NTFS, 4kB) @ Seagate ST1000LM024 HN-M101MBB (1TB, SATA600, 2.5", 5400rpm, 16MB Cache)
Audio CD (E:) : N/A (CDFS, 2kB, Read-Only) @ hp DVDRW SU208GB (573.5MB, SATA150, DVD+-RW, CD-RW)
Peripherals
LPC Hub Controller #1 : HP Wildcat Point-LP LPC Controller
Audio Device : HP Core (Broadwell) Audio Controller
Audio Codec : Intel 2808
Audio Device : HP Wildcat Point-LP High Definition Audio Controller
Audio Codec : Realtek Semi 0290
Disk Controller : HP Wildcat Point-LP SATA Controller [AHCI Mode]
USB Controller #1 : HP Wildcat Point-LP USB xHCI Controller
SMBus/i2c Controller #1 : Intel ICH SMBus
Printers and Faxes
Printer : HP ePrint (600x600, Parallel, Colour)
Printer : Foxit PhantomPDF Printer Driver (2400x2400, Colour)
Network Services
Network Adapter : Realtek PCIe FE Family Controller (Ethernet)
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Wireless Adapter : Broadcom BCM43142 802.11 bgn Wi-Fi M.2 Adapter (802.11n (HT), AES-CCMP, 72Mbps)
Power Management
Battery #1 : Hewlett-Packard Primary 37.41Wh/2.24Ah
Operating System
Windows System : Microsoft Windows 8.1 Personal 6.3.9600
Platform Compliance : x64
Performance Enhancing Tips
Warning 2513 : TPM not detected. Some security features are unavailable.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 03-06-2018, 01:43 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I would recommend you only do some minor experimenting with this hard drive. Even with the First software rather than full versions audio streaming at 16 bit 44.1 will tear up that drive very quickly-its read/write cant cope. A small SSD is best but you can get away using a faster spinner hard drive. As for the hardware in use message: the Pro Tools Avid Audio Engine(AAE) requires control of whatever audio I/O it has designated for use, usually its going to look for an ASIO or Avid hardware first then the windows sound last. If you want it to use the 2i2 you need to go into the sound control panel and set the windows sound (usually realtek audio) as the default sound output, not repeat not the focusrite. 2i2 should be enabled in recording and output tabs but not default. In the advanced options tab for either I/O you plan on using(2i2 or WASAPI) you can set the sample rate etc. for your use 16 or 24 bit 44.1 k is suggested. Also to use the 2i2 PT needs to have an asio driver to work through , this is available on the focusrite website or you can use ASIO4ALL. Note: PT can also use the windows built in audio as an I/O by holding down the "N" key while starting PT and choosing "WASAPI" as output. This is also the best way to start up when you haven't set your system up yet.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
  #16
Old 03-06-2018, 03:50 PM
amagras amagras is offline
This will probably help
https://youtu.be/d2a3kTqM0y8
There's a lot of good advice for Windows users in this YouTube channel and you can ask @benoni directly as he's a moderator here
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Error: "The I/O Layout of the Audio Hardware has been changed by another application" henrybcisneros macOS 6 09-16-2015 06:01 AM
"Hardware controls for this peripheral are handled in its Setup Application" pilipinokuno Pro Tools M-Powered (Win) 1 02-07-2012 03:57 AM
"Hardware controls for this peripheral are handled in its Setup Application" pilipinokuno Pro Tools 9 1 02-05-2012 05:50 PM
Another "Unable to locate Digidesign hardware" error message Albers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 05-28-2011 11:12 AM
Application "Null" error message in launch Jay Wilson Digidesign Hardware & Software 6 12-18-2002 02:37 PM
