ozone 3.15 on masterfader gives mono output
I'm running Ozone 3.15 as a stereo plug in insert in PT LE 7.4 CS3 (macbook Intel Pro 10.4.10 with glyph audio drive) on the master fader and the stereo sound comes out in mono !
I check the phase correlation in the plug in and it gives a phase correlation of 0, meaning mono signal. If I bypass the plug in I get the stereo sound back and if I replace the plug in by the Oxford limiter f.i. it is stereo. Any one experienced this? best Regards, chicken
New shoes always hurt. |
Re: ozone 3.15 on masterfader gives mono output
I recently had a strange issue with Ozone on the master fader, it was when audio passed over regions that had been manipulated with elastic audio. In the end i removed the plugin because it was causing a flanged type phasing effect.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
hmmm, interesting. I also used elastic audio
Any one some more ideas? I've posted this question to Izotope support but I have to wait since they have an imposible amount of questions to anwser and yada yada yada Chicken
BUMP.
Anyone? Please? Pleeaaassssssseeeeee???
I just realized today that I too am getting Mono signal out of it. I thought something was wierd, so I A/B'd the master channel by bypassing the Ozone. Damned if it wasn't going to mono when I enabled it. I stripped it off my system and will not use it again.
Well, maybe I would, but I'm not going out of my way, as I've found a happy substitute in Phoenix.
Veni, Vidi, Funki - I came, I saw, I laid the stank down System 1: Retina MBP 512SSD/16RAM - Thunderbolt HDX1/HDIO System 2: Mac Mini - 512SSD/8RAM - Thunderbolt HDX1/HDIO OSX 10.8.5 Pro Tools 10 HD Pro Tools 11 HD SYNC HD |
The same problem here
OS 10.8.5 , Mac Pro 2.8 GHtz , 8GB RAM, Digi003,PT10 |
Ozone 3 ALWAYS returns mono as RTAS | eric22rr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-28-2011 01:35 PM |
Ozone outputs mono only, even on stereo track | eric22rr | The Drum Room | 1 | 01-23-2011 07:36 AM |
I only have mono on output or monitors | MichaelDiFede | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-04-2009 08:53 PM |
PC Output in Mono? | stuart97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 09-03-2008 08:19 AM |
When you output a stereo aux track to a mono output? | el biciclista | Pro Tools TDM Systems (Mac) | 5 | 06-04-2003 12:10 AM |
