Protools TDM HD3 6.7 / macos 10.5.3 Midisport 1x1 / g4
This has never been an issue in the three years that I have had this system, but suddenly I can't see or hear midi signal when I try to record midi through my keyboard. Strangely enough, as there is no signal in the vu meter thing, you can see the midi getting recorded to the piano roll. Then you can play the recorded midi back normally. I am perplexed, after reinstalling both the drivers for the midi device AND the protools software (and all my plugins. Gaaah) Help me Ob-1 You're my only hope! Keny
just to toot my own horn, I am in the process of relocating to Los Angeles and lookign for a job, so if anybody knows someone who can help me get established as an audio engineer and producer, check out my creds at http://www.kenyruyter.com and call me 310-909-9115 myspace page http://www.kenyruyter.com |
check your input devices under the midi menu. mmm..... does ams recognize it? does the input show up on the midi track or is it set to all?
Yeah it is recognized and all the pop ups in the input/output are correct. The midisport shows up in the midi devices menu. All appears normal.
ok. i think what is happening is that I am using a session that was recorded at another studio, and after I open it in my protools, it corrupts the midi functionality somehow. I have done a few reinstalls, and it seems to go bad after I open that one session. So, I am trying to import the tracks into a new session and see how that goes. But i also think i may just have the problem at 24/44.1 I still need to test stuff further, but at the least i think i have a handle on it.
Make sure you have MIDI Through selected. It's under the MIDI menu in 6.4.1, not sure about later versions. Having MIDI Through deselected would explain your behavior perfectly.
If all else fails... Try trashing the AMS prefs and rebulid your midi studio! ams prefs are in user/library/prefs. Chris
PT MAC Troubleshooting... http://duc.avid.com/showthread.php?t=54888 Producer, Engineer, UKmastering Mixing & Mastering Blinders_Columbia top 40 UK album charts Slow Readers Club_Build A Tower top 20 UK album charts www.ukmastering.com PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring. |
Downgrade to OS 10.4.6
Sorry.. Check & load back your standard I/O Setup.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
Midi issues in PT9 | stresstour | macOS | 1 | 03-28-2012 08:17 PM |
MIDI Issues!!!! HELP!!!! | trickykeys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-08-2006 05:53 PM |
MIDI Issues | myque Peters | MIDI | 4 | 08-28-2005 12:05 PM |
Midi Issues | Polyph | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 10-14-2003 07:41 AM |
Are there big MIDI issues in 6.1 ? | Ivory Tower | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-25-2003 10:31 PM |
