Old 07-13-2016, 09:21 AM
Dayliner Dayliner is offline
Default 003 and Rosetta 200 wont sync
I've used the same 003 and Rosetta 200 for eight years. I have them connected via SPDIF. In the last couple months I've had to work in Internal mode because they won't sync all of a sudden. When I switch to SPDIF in Hardware to sync them the Rosetta starts blinking lights erratically, and there's either no sound, or incredibly staticky sound.
-the Rosetta does still correctly lock to the correct bit resolution and sample rate.
-Been running OSX Yosemite 10.10.3 for a year.
-I've been able to use PT 10.3.2. and 12.1.0 on the same rig. The former because of plugins that only work there, that i haven't updated for 12 yet.
-003 has latest firmware.
-SPDIF cables are correctly plugged in.
I have to print an album's worth of songs now, and i need the clocking from the Rosetta. Can anyone help me please? Yeearrggh
Old 07-13-2016, 11:38 AM
EGS's Avatar
EGS EGS is offline
Default Re: 003 and Rosetta 200 wont sync
What has changed recently? It sounds like a hardware issue, but just in case, can you restore your computer back to a boot-drive image that worked previously? Try a new SPDIF cable? Does the 003 work properly without the Rosetta connected at all?
Desktop: PT 2019.10 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 10 / Win 7 / HP ProBook / i7 quad / 8GB / U-PHORIA UMC1820
Legacy rig (works): PT 5&6 / MAC G4 OS9&OSX / DIGI001
Info/Services link
Old 07-13-2016, 01:23 PM
-003 works perfectly fine
-SPDIF cables are fine
-i'm leery of restoring a time machine backup, for fear of messing up final mixes i need to shoot off
it's the damn oddest thing. would i maybe need to re-up the rosetta firmware? you need a USB to Midi connection to do that right?
Old 07-13-2016, 03:21 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by Dayliner View Post
...leery of restoring a time machine backup ...
Time machine is ... not best ... for the purpose of writing/storing/restoring boot drive images. Google for free and paid options. Restoring your boot drive to an earlier known working version should never make you leary but rather, consider it a solid backup plan!
Info/Services link
Old 07-13-2016, 07:09 PM
Top Jimmy's Avatar
If the Rosetta starts misbehaving when you change settings on the 003 then it sounds like the Rosetta is slaved to the 003 clock. The Rosetta should be the master and the 003 the slave.
One thing you could do is trash the prefs and databases to be sure the 003 settings aren't corrupt. http://www.sweetwater.com/sweetcare/...s-preferences/
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2019.10, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 07-14-2016, 09:35 AM
Hmm OK. What can i expect to happen to the operation of either PT versions when I delete their prefs?
Sync problem between Rosetta 800 and 192 Firewater Studios Pro Tools TDM Systems (Mac) 1 05-26-2011 05:25 PM
HD1 and Rosetta MIDI Sync Issues theoutlierinn MIDI 0 04-21-2008 09:39 AM
how to sync g5 digital output for use with rosetta blumediaprojekt Pro Tools TDM Systems (Mac) 4 02-18-2006 12:27 PM
HELP!!!!! - Rosetta sync issues danocaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-03-2002 04:18 PM
HELP/? about USD sync to ATR thru Apogee Rosetta AD James Thomas Pro Tools TDM Systems (Mac) 0 01-02-2000 07:14 PM
