Old 08-04-2009, 11:18 AM
keny keny is offline
Default file recovery
Hello, I am using the program "data rescue" on a hard drive to recover deleted .pts files and I am not having any luck. Can anyone recommend a software app that can read deleted .pts files off of a hard drive? (better yet one that actually recovers the original file names as well...)
Thanks,
keny
just to toot my own horn, I am in the process of relocating to Los Angeles and lookign for a job, so if anybody knows someone who can help me get established as an audio engineer and producer, check out my creds at http://www.kenyruyter.com and call me 310-909-9115
myspace page
Old 08-04-2009, 09:49 PM
JC925602 JC925602 is offline
Default Re: file recovery
From another tread on the DUC
Originally Posted by pablotec View Post
Hello:
You can uso following programs:
- Data Rescue II
- FileSalvage
- StellarPhoenix 3.0
I recomend you DataRescueII to find audio files and FileSalvage to recover sessions reels (you must to add this file format (.ptf/.pts) manually in the program prefs) .
When you deleted audios from a HDD you need to know:
- Never write in the damaged/deleted volume!!!
- Use a second drive for recover files
Because we are using audio files and in some cases are loger than 100Mb, you need to "modify" basic setup of recovery engine of DataRescueII to make "visible" to the program this files.
Go to:
DataRescueIIreferences/scan engine/filemodules/audio
The program can search all audios formats except SD2 (if you are using SD2, you will need FileSalvage, because you can add unknow files to a search engine).
Select the audio format that you are searching and modify the "maximum file size" to 2000Mb
Search in the volume deleted audio files.
You can try all programs before buy it, you can download from respective manufacturer pages.
Regards
Pablo Medrano
JC
Old 08-05-2009, 12:41 AM
thanks! it figures I should have searched the duc....
myspace page
Drive recovery or file recovery bobmaus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-13-2006 04:00 PM
File recovery mrgummy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-03-2005 01:23 PM
File recovery for PT 7?? poppy Pro Tools TDM Systems (Mac) 1 05-26-2005 01:44 PM
PTS File Recovery RuckusEnt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-26-2003 06:22 AM
Best File Recovery Prgrm for OS9? pontuso Pro Tools TDM Systems (Mac) 1 05-20-2003 01:48 AM
