Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Mac)
Old 04-11-2018, 11:19 AM
dgbeem dgbeem is offline
Default insertion follows playback not working
Any thoughts on why "insertion follows playback" suddenly stopped working? I have deleted my PT preferences and still have the same problem.
So, do I need to re-installl?
Thanks
Old 04-11-2018, 12:53 PM
Stig Eliassen's Avatar
Default Re: insertion follows playback not working
Welcome to the community.
Well, you don't give any information about your system, nor how PT behaves. If you're sure insertion follows playback is enabled, I'll guess that an unwanted pre-roll is enabled.
Old 04-11-2018, 01:13 PM
BScout BScout is offline
Is the indicated option for "insertion follow playback" lit up on the button under the tools?
What is your playback mode (see the transport)?
If you post a picture of your edit window, it's usually easy to tell if something got clicked (the playhead/playline changes color, etc.) to a different mode.
Pro Tools Ult 2018.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.12.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 04-11-2018, 05:23 PM
Click image for larger version
Pro Tools 10 running under OS10.7.5 This is the first hiccup I have had since late 2012. Video and audio stored on an external firewire drive.
I'm also running 4.15 macOS 10.13 High Sierra on the same laptop but the problem began before using two operating systems.
I am aware of the "insertion follows playback" button and changing it does no good.
Thanks
Name:	PT screen.jpg
Old 04-11-2018, 05:57 PM
You have dynamic transport on. Turn that off.
Also make sure the following is checked in Preferences:
Old 04-11-2018, 07:51 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
There is a bug if you have "quick-punch" engaged it doesn't work.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 04-11-2018, 09:32 PM
Thanks Eric, you nailed it!
Working fine now. I seldom actually record since I'm usually sweetening video or doing sound design. Recently, I started using a bus to send my mix to an audio track instead of the customary "bounce to disk". That way I can watch picture as I print. (Makes me feel more comfortable)
I probably engaged "quick punch" by accident.
I appreciate your help!
G
Insertion follows playback Philharmonic7 Pro Tools | S6 4 04-20-2017 01:46 AM
Insertion Follows Playback not working Pro Tools 12.6 nofx1609 Pro Tools 12 6 10-17-2016 08:14 AM
Insertion follows playback. Seeee Pro Tools TDM Systems (Mac) 2 03-13-2006 05:41 PM
insertion follows playback KingTor ProControl, Control|24, Command|8 5 05-22-2001 05:23 PM
