"Assertion" Error when using Sound Miner
Sound Miner worked fairly well with PT9 until today. For no obvious reason at all, I suddenly get the following error, when I try to transfer a file from Sound Miner to PT:
Assertion in"[...]Sys_FileLoc.cpp", line 199 I didn't change anything, it suddenly appeared. The files are copied to the desired folder, but they are not imported into PT. Any ideas?
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Re: "Assertion" Error when using Sound Miner
This thread is too old. I guess by now you have achieved the solution for the stated problem. However, Google searching on this topic brought me to this forum, and I hope many more will arrive at this place in future, looking for solutions. Hence I am stating how I got through this problem.
Most of our pro-tools projects are in 24 bits. Just by intuition I checked the "Preferences" settings on my SoundMiner V4Pro and I found the bit depth was set there to 16! I changed that to 24 and after that, my sounds are smoothly flowing into ProTools from Soundminer, without any hassles. I hope this would help. If this solution worked for you, don't forget to state it here. I will feel nice that I solved someone's problem. |
Strange "Assertion" error causing Pro Tools to quit unexpectedly...???? | nickbradbury | macOS | 13 | 09-10-2014 03:50 AM |
Help for Error Message - Assertion in "..\Mdie_TrackPlayer.cpp", line 476 | lbpease | Pro Tools 10 | 7 | 01-05-2014 12:15 PM |
assertion in "..\Mdie_TrackPlayer.cpp", line 469 / access violation/ DAE error -9400 | thibault | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-22-2013 05:08 PM |
Error: "pro tools could not complete the import audio command because assertion in" | elsterNJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-15-2009 09:38 AM |
PT 32t beta weird error- "an assertion occurred..." | jes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-07-2002 09:16 AM |
