Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 01-28-2015, 02:07 PM
BigJohnD BigJohnD is offline
Default Avid Pre remote control from Pro Tools
I’m currently on a PT 11.3 HD Native setup on a PC (Windows 7) with an Omni as audio interface. Everything currently seems to work well. From time to time I fantasize about getting more mic inputs. The Avid Pre interests me but I don’t understand how the Pre supports remote control (via MIDI?) through Pro Tools. Is there a user interface in PT HD? Does it have to be set up through Setup-> IO menu option?
I’m interested in how to control an Avid Pre remotely via the PC. Can it be made to work on an HD Native system?
As far as I can tell, the Omni does not do MIDI. But I have an Mbox 3 which does have a MIDI interface. Would this be of use?
I'm a bit over my head on this issue. If someone with some experience could point me in the right direction, it would be appreciated.
Thanks
Old 01-28-2015, 03:06 PM
Craig F Craig F is offline
Default Re: Avid Pre remote control from Pro Tools
yes, the Pre is controlled via MIDI, you set it up under Peripherals, and show the Pre controls in the Mix and/or Edit window
I don't know if the mBox's Midi will work with the HD system in play, you may need a dedicated Midi interface (the low end MOTO is my recommendation if the mBox doesn't work)
with the OMNI only have 8 inputs active your not gaining a lot with the Pre
Thank you,
Craig
Old 01-28-2015, 04:57 PM
Craig,
Thanks for the information.
John
Pro Tools remote control with TouchDAW? sdart Windows 1 05-19-2014 07:03 PM
motif xf Pro Tools remote control akhafaji Pro Tools 10 2 03-14-2012 07:08 AM
Remote Avid by Pro Tools olaf089 Post - Surround - Video 5 02-09-2008 01:38 PM
remote control of pro tools therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-20-2007 01:38 PM
01V remote control of pro tools Papus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-23-2002 06:05 PM
