Help! Errors 9092, 9093, 9094, 9129 persisting!
Is anyone able to give me a hand?
Just about every time I try and record or play during a Pro Tools session I get either error -9129, suggesting I reduce the H/W Buffer Size, but when I do that I get either error -9092, -9093, -9094 asking me to increase the H/W Buffer Size. I've gone through all the troubleshooting tips I found here: http://duc.digidesign.com/showflat.p...fpart=1#802377 , but nothing seems to help. Even when I load a Tools session and make all but one track inactive I still get the problem, sometimes it even asks me to increase the CPU allocation, although it's on 85 percent and the usage meter shows it's not taxing the computer at all. I'm running Pro Tools LE 7.1 on the Mbox 2. Computer details: OS: Windows XP Pro, Service Pack 2 CPU: AMD Athlon 64 Processor, 2200 MHz (11 x 200) 3500+ Motherboard: Gigabyte GA-K8U-939 (5 PCI, 1 AGP, 4 DDR DIMM, Audio, Lan) ULi/Ali M1689, AMD Hammer System Memory: 1024 MB (PC3200 DDR SDRAM) Storage: 2x ST320414A (20 GB, 7200 RPM, Ultra-ATA/100) 1x ST3250823AS SCSI Disk Device (250 GB, 7200 RPM, SATA) Any help at all would be *really* appreciated - I'm going nuts here.. Geoff |
Re: Help! Errors 9092, 9093, 9094, 9129 persisting!
Please follow these instructions from that thread:
Yeah, I did get that report, but when it came out as 900-odd pages long I thought I'd just give the bare bones myself. This is the information under "Computer Overview", let me know if you need any more. Thank heaps for checking this out!
Geoff << Computer Overview >>> -------------------------------------------------------------------------------- < System > Host Name: GEOFFS User: Geoff Workgroup: WORKGROUP < Processor > Model: 1x AMD Athlon(tm) 64 Processor 3500+ Speed: 2.21GHz Model Number: 3500 (estimated) Cores per Processor: 1 Unit(s) Threads per Core: 1 Unit(s) Internal Data Cache: 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache: 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size < Mainboard > Bus(es): ISA X-Bus AGP PCI USB i2c/SMBus MP Support: 2 Processor(s) MP APIC: No System BIOS: Award Software International, Inc. F3 Mainboard: Gigabyte Technology Co., Ltd. M1689D Total Memory: 1GB DDR-SDRAM < Chipset 1 > Model: Giga-Byte Technology ULi M1689 K8 Northbridge with AGP and hypertransport Front Side Bus Speed: 2x 1005MHz (2010MHz data rate) < Chipset 2 > Model: Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed: 2x 1005MHz (2010MHz data rate) Total Memory: 1GB DDR-SDRAM Memory Bus Speed: 2x 201MHz (402MHz data rate) < Video System > Monitor/Panel: Plug and Play Monitor Adapter: NVIDIA GeForce 6600 GT < Physical Storage Devices > Removable Drive: Floppy disk drive Hard Disk: ST320414A (19GB) Hard Disk: ST320414A (19GB) Hard Disk: ST3250823AS SCSI Disk Device (233GB) CD-ROM/DVD: LITEON CD-ROM LTN526 (CD 52X Rd) CD-ROM/DVD: PIONEER DVD-RW DVR-106D (CD 32X Rd, 16X Wr) (DVD 4X Rd, 2X Wr) CD-ROM/DVD: SCSIVAX DVD/CD-ROM SCSI CdRom Device (CD 32X Rd) (DVD 4X Rd) < Logical Storage Devices > System (C:): 19GB (4GB, 21% Free Space) (NTFS) Video (D:): 19GB (1.9GB, 10% Free Space) (NTFS) Audio&Games (E:): 233GB (51GB, 22% Free Space) (NTFS) CD-ROM/DVD (F:): N/A CD-ROM/DVD (G:): N/A CD-ROM/DVD (H:): N/A 3.5" 1.44MB (A:): N/A < Peripherals > Serial/Parallel Port(s): 2 COM / 1 LPT USB Controller/Hub: ALi PCI to USB Open Host Controller USB Controller/Hub: ALi PCI to USB Open Host Controller USB Controller/Hub: ALi PCI to USB Open Host Controller USB Controller/Hub: Standard Enhanced PCI to USB Host Controller USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Composite Device USB Controller/Hub: USB Composite Device USB Controller/Hub: Digidesign Mbox 2 Firmware Updater Keyboard: HID Keyboard Device Mouse: Microsoft USB Wheel Mouse Optical Human Interface: HID-compliant device Human Interface: HID-compliant consumer control device Human Interface: Microsoft USB Wheel Mouse Optical Human Interface: USB Human Interface Device Human Interface: USB Human Interface Device < MultiMedia Device(s) > Device: Standard Game Port Device: Realtek AC'97 Audio < Printers and Faxes > Model: Microsoft Office Document Image Writer Model: Lexmark Optra E312 (MS) Model: Canon Bubble-Jet BJ-200 < Power Management > Mains (AC) Line Status: On-Line < Operating System(s) > Windows System: Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) Platform Compliance: Win32 x86 < Network Services > Adapter: Realtek RTL8139/810x Family Fast Ethernet NIC < Performance Tips > Warning 100: Large memory sizes should be made of Registered/Buffered memory. Tip 2546: Large memory modules should be ECC/Parity. Notice 5901: CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902: DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2: Double-click tip or press Enter while a tip is selected for more information about the tip. |
"Computer Overview" is all that is needed. (Digi should make note of that in those instructions...)
As I said, the Uli/Ali chipset is not supported, and I think is really your main problem. Most "inexpensive" chipsets tend to cut corners in areas that Pro Tools requires. There are a few other things that stand out as being potential problems:
Thanks, that's some good stuff to work with.
Alcohol showing up is my fault - I always ensure that's closed when running Tools, just must have rebooted when I ran the system report program. I did have a alternate boot for the computer to make sure that it was optimised for running Tools that eliminated things like alcohol, the printers, network card, etc. but it didn't seem to help. So if the problem is just with the Uli/Ali chipset hopefully I can get it resolved sooner rather than later. Unfortunately there's a limit to my general computer knowledge, so are you able to explain the chipset situation further? If it's hardware, then can it be replaced without needing a new motherboard, cpu etc.? I assume the Digidesign page would have chipsets they recommended? Thanks again for getting back to me, G |
The chipset is part of the motherboard. To replace the chipset, you would need to replace the motherboard (and possibly other components, depending on compatibility with whatever new motherboard you choose).
Hi everyone,
I was going to post my own topic on the forum but this seems to be the same problem I have, so I'll post it here first. I have a MusicXPC M4x Laptop (built specifically for programs like Pro Tools) equip with an Intel Core 2 Duo 2.0 GHz processor along with 2.0GB of RAM. I have a dedicated graphics card and I've tried recording both to an external hard drive and to the internal one (both on a separate partition and on the local one). I am running Mbox 1 with Pro Tools 7.3.1. I can't record anymore than 30 seconds of audio even with only 1 audio track, and using virtual instruments is out of the question. I get the same errors as the guy above, saying I need to either increase or decrease the H/W buffer size, but in Windows Task Manager my CPU usage isn't even at 15% and under Pro Tool's System Usage window, the CPU meter remains at a static low level, but here is the strange part... it randomly spikes and peaks in the red, even when nothing's going on in Pro Tools. What in the world is the cause of this? I'll try posting this question in the main forum if I don't get any answers here...
A Digidesign user spends 1/3 of his life in bed, 1/3 of his life working, and 1/3 of his life talking with technical support. |
You're also doing what we call "thread stealing" and it generally considered to be rude. It distracts from the original posters question, and the possible solution for his specific issue. Please, read through the General Troubleshooting thread that is "stickied" at the top of this forum, and if none of the suggestions there help you, then post details about your system using the SiSoft Sandra software as recommended in that post, and specific details about the problem you are having in your own separate thread.
Geez, excuse me for avoiding clutter on the main board. All other forums I post at you get blasted for creating a similar thread to one that's already existing. The errors were the same, so I thought I'd start here first.
Ok, thanks for all your help. I've looked over all the suggestions and tried everything, so it seems like it's definitely not a software issue. I've checked out a couple of threads here over which motherboard to buy but it also seems like I'll need to replace most other components of my computer to be compatible with a new motherboard. But it does seem to be a waste of a perfectly fine computer for anything other than Tools. I might just buy a mac.
Thanks again for all your help, it's been really appreciated, G |
Please help, getting errors 9092 9093 9094 6086 | Mekko511 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 02-24-2010 11:00 AM |
overcome pro-tools errors 9092, 9093, 9094 | Deni | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-11-2008 11:59 AM |
errors 9092 9093 9094 | gibboau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-20-2008 08:49 AM |
-9092 -9093 -9094 errors on PT LE 5.2.1 | Chuck P | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-13-2004 08:24 AM |
Interrupt errors -9092/ -9093/ -9094/ -9129 | saxbill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-18-2002 11:41 AM |
