Finding fizz and removing it with EQ
hello guys,
I'm trying to learn how to find disturbing frequencies and removing them with EQ. I watched a couple videos and read some articles but it seems I'm still not doing it correctly. I narrow the Q and put it at least 12dB, then what? I sweep through frequencies but what should I actually look for? I hope that's clear enough so you can get my point. Thanks. |
Re: Finding fizz and removing it with EQ
The first thing to consider is the gain. How much gain do you need, maybe try reducing the gain, then you may want to try reducing the treble.
For the P-EQ, I usually look around 4k to 6k for the fizz. Sometimes you may find the fizz in the 2k range, every amp-cab-mic combo is different.
example: http://www.youtube.com/watch?v=QaIvzbV40MM how does he know he found the correct frequency to trim? I guess it's something like "the frequency which disturbs you gets much louder so you cut it there" but I'm not sure. There are some people who do that by tracking the whistle sound as they sweep through different frequencies, I didn't get that as well. |
003r/i7-930/LE 8.0.1 cs2 on xp |
By the way, for other people out there who want to learn how to do this, it is not called "finding fizz and removing it with EQ" but "subtractive EQ" or "notch filtering". You find lots of articles and videos over google. Thanks for all replies. |
Here is a little nugget I found a while back that has really helped me get better guitar tones using Amp Sims.
How to Make Amp Sims Sound More “Analog” http://www.harmonycentral.com/docs/DOC-1652
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
I think that's where ur ears come in. -what sounds good to u ? Solo'd is one thing and in the mix sound is another - what sounds the best to u??
Whoops saw the other post after I posted - haha
I usually get rid of the fizz without resorting to the PEQ.
First, add some speaker breakup - a setting of between 3 and 3.5 works for me, YMMV. Second, experiment with cabs and mics and mic placement. Forget about what they're called, just LISTEN to them. Sometimes, the sound that's in your head that you think should be achievable with an AC30 and 2x12 with an SM57, is better achieved with a Plexi50, 4x12 with Vintage 65s, and a 409. Again, it comes down to listening and not looking. |
The fizz that wasn't really there | Deny | Eleven Rack | 2 | 08-13-2011 02:58 PM |
Weird fizz making sound when Re-Amping | JustGoWithIt | Eleven Rack | 6 | 08-03-2011 07:11 AM |
11r Standalone XLR Noise/fizz, hum | fly_with_v | Eleven Rack | 4 | 12-13-2010 10:04 AM |
getting rid of fizz/noise | SloeGin | Eleven Rack | 3 | 11-14-2010 02:00 AM |
fault finding by removing plug-ins... | AdamPT8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-17-2010 11:03 AM |
