  #251
Old 03-27-2008, 05:47 AM
Gothboy's Avatar
Gothboy Gothboy is offline
Default Re: PLUGGO 3.1 OSX IS A-GOGO!!
Can anyone give me an explanation of how to go about installing/upgrading and using Pluggo runtime 3.6.1? I've been using(or not using, they're so many and I just didn't get to use them!..) pluggos in 3.5.4 in Panther, but now that I'm running Tiger 10.4.11 and PT 7.3 I'd like to use pluggos that work with 3.6.1 but only a select few. What folders to I need to get rid of and how do I install 3.6.1? This is on a PPC machine so I know I can't run UBs,,,,right?
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core
16 GB RAM
Mountain Lion 10.8.5/El Capitan 10.11
Focusrite Saffire Pro 40
Ableton Live 10/Presonus Studio 3
  #252
Old 05-28-2008, 01:31 AM
basik basik is offline
new ub pluggos
see
http://pedrofilipeguerreiro.wordpress.com/vst-plug-ins/
Abril 11, 2008, 7:54 pm
Arquivado como: Não classificado
I’ll be uploading my suite of audio plug-ins for you enjoynment.
No documentation yet, sorry. Please try the presets. Thank you.
Audio Effects
tram - granulation-delay-degradation
tram_m - multiout version of tram
Synths
Mudulators
_tickr - in tempo probability random & ramp
downloads
http://clientes.netvisao.pt/pedfilg/...osx_Intel).zip
  #253
Old 05-28-2008, 01:34 AM
new ub pluggo
opfour (Beta) : 4OP FM TONE GENERATOR
see
http://www.audiooo.com/jp/freestuff/pluggo.html
downloads
http://www.audiooo.com/jp/download/opfour_beta1.zip
  #254
Old 05-28-2008, 01:37 AM
new ub
see
http://www.basementhum.com/2008/04/s...r-ableton.html
basement_crossfade is a very simple plugin primarily designed for use in Ableton Live. It accepts two audio inputs and a single crossfade control determines the mix sent to its output.
downloads
http://www.bitbutter.com/public/base...ssfade.vst.zip
  #255
Old 05-28-2008, 01:44 AM
ub new
see
http://www.philosound.net/index.php?...rsions&catid=1
Transmit and Receive MIDI over Ethernet. Standalone Application and VST-Plugin for transmitting MIDI Data; Standalone Application for multicasting MIDI Clock over LAN; Universal binary. Required (Plugin): Cycling´74 Pluggo Runtime
downloads
http://downloads.philosound.net/mnus...%20-%20osx.dmg
see
http://www.philosound.net/index.php?...d=28&Itemid=47
The S3 - Stochastic Step Sequencer is a VST/AudioUnit/RTAS Plugin, being a
16-step Impuls Sequencer, which delivers a mode, where the steps´ values are fed into a stochastic algorithm.
The intended goal hereby is musical usability, not the mathematically possible of randomness.
The plugin supports midi and sample output.
The S3 - Stochastic Step Sequencer is being developed in Cycling ́74 Max/MSP -
downloads
http://downloads.philosound.net/S3/S3.dmg
  #256
Old 06-09-2008, 12:22 AM
http://homepage.mac.com/sinx_music/download/index.htm
2008/06/03 Release "PWM" for MacOSX
2008/06/01 Release "RM" for MacOSX
2008/06/01 Update "AM3.0" for MacOSX
2008/05/29 Release "Scratcher" for MacOSX
Modulation
PWM
-- Pulse Width Modulation
P1"Mod" = Modulation (Hz)
P2"PW" = Pulse Width (Hz)
P3"Deapth" = Depth (Hz)
P4"Dry" = Direct Level
downloads
http://homepage.mac.com/sinx_music/d...M_plug.vst.zip
Modulation
RM
-- Ring Modulation
apply ring modulation to stereo input source
P1"RM" = Modulator Frequency (Hz)
P2"Deapth" = Depth (Hz)
P3"Mode"= Wave Mode (1:Sin, 2:Saw, 3:Saw, 4:Pulse, 5:Random)
P5"Duty" = Pulse Width(If Mode5)
P6"X" = Modulator Frequency Multiplier
Download
Modulation
AM
-- Amplitude Modulation
apply amplitude modulation to stereo input source
P1"AM" = Modulator Frequency (Hz)
Download
http://homepage.mac.com/sinx_music/d...0_plug.vst.zip
Experimental
Scratcher
-- Automatic DJ-Scratching for input source
P1"Speed" = Scratching speed
P2"Complex" = Complexity of scratch
P3"Skill" = Scratching skill
P4"Dry" = Dry Volume
P5"FX"= FX Volume
Download
http://homepage.mac.com/sinx_music/d...r_plug.vst.zip
Pluggo jr clausiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-21-2006 07:57 AM
Pluggo on 6.7? keny Pro Tools TDM Systems (Mac) 4 01-11-2005 04:35 AM
Pluggo and FCP HD Darin Donovan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-11-2004 07:29 PM
who uses pluggo? freakuincy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-05-2003 08:52 AM
* PLUGGO 3 peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-05-2002 03:35 AM
