Old 01-11-2014, 12:15 PM
studiostrat studiostrat is offline
Default Okay,I gave up on my 002.My 003 is not passing audio through when using LLM in PT 10
So,I also have a 003 Rack.It works great as a playback device,but it will not pass through audio when I engage Low Latency Monitoring (even on inputs 1 and 2)and the record light on for the specified input.I cannot hear anything when I switch to 'input only monitoring' and mute the track(like when I had an Mbox).In both cases,when I sing/bark into the mic,the meter shows input,but there is no sound present.It will pass audio if I turn LLM off or if I turn input only monitoring off.I did some research.I looked at my IO setup and defaulted everything.I am using the 003 as my playback device.This is noooo good.Someone please help,if you can.
Studiostrat
BNR (DINR) TDM not passing audio Jamshied Pro Tools TDM Systems (Mac) 30 06-28-2010 12:59 PM
No audio passing through Mbox2 Pro wrkingclassoi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-29-2008 11:43 AM
core audio conects , but no audio passing threw audiomania Pro Tools TDM Systems (Mac) 2 08-23-2006 07:41 AM
882/20 input not passing audio Craig Woolard Pro Tools TDM Systems (Mac) 1 07-17-2000 10:51 PM
Am I Passing 24bit Audio or What zeeman Pro Tools TDM Systems (Mac) 4 10-12-1999 10:34 AM
