PT11 restart
Why does it require a restart in PT11 once everything is loaded when PT11 says the control panel has detected a change and forces you to close your session and reopen.
It seems elementary for this kind of nonsense. I am a new user to PT as I bought an ER recently and received PT 10/11 with it. I am used to Sonar but am trying to fall in love with PT. Annoying and surely PT can make adjustments on the fly, after all it is the industry standard for audio recording isn't it? |
Re: PT11 restart
If this is a problem, it's back to Sonar I suppose. Enjoy. |
Re: PT11 restart
Thanks, but I already had that much figured out. I actually was anticipating that someone knew a work-around or could help me identify an error that I was contributing to the issue.
Oh, and I don't have a problem using Sonar but am happy to be an avid PT11 trainee. Sorry if I ruffled some feathers. |
Re: PT11 restart
No feathers ruffled here
If I were in your shoes I would reinstall Pro Tools, restart the computer after trashing preferences and everthing and see if that helps. Inhave never seen your issue here before but worth a try first Best of Luck Christopher
Re: PT11 restart
It seemed to me that you were asking for a work around for normal PT behavior. Is that not the case? Your post didn't make that clear to me, sorry. |
Re: PT11 restart
That kind of prompt indicates that your sound card is in use by another application, preventing PT from telling the driver to switch sample rates.
If you're on PC, set your default Windows playback device to something else. EDIT: Oh, you're changing the sample rate manually with a session open? Yeah, it'll make you reopen. |
Re: PT11 restart
Thank you, I will do a bit more investigating before I do a re-install. It is annoying but doesn't seem to affect anything once I restart. My interface is a focusrite LS56 firewire. I always turn on the LS56 and Eleven Rack prior to booting my PC AudioLabs computer. I read where other users are seeing both the ER and their interface listed in playback engine but I only see the LS56 so I go to i/o and set them to default which allows me to see all i/o for both units.
PT11 seems a little glitchy regarding that part but it works so far. It may be that the first interface it sees it locks on to. Like I said I'm a rookie but am very interested in PT11 as well as the ER. |
Re: PT11 restart
If your drivers are installed correctly and the computer recognizes the Eleven Rack, then you should be given the option to choose it in Setup> Playback Engine.
Re: PT11 restart
Yes I agree. I have booted PC without the LS56 and the ER is the only option in playback engine but when I boot my PC with both LS56 and ER only the LS56 is the option in playback engine. I am sure all drivers are up to date.
Re: PT11 restart
Could a faulty USB cable on the ER cause these issues?
PT11 to PT11 HD Native upgrade without hardware? | kirkbross | Pro Tools 11 | 2 | 11-04-2013 03:10 PM |
"you need to restart" HELP! | Eless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 01-24-2005 01:37 AM |
Restart | DWdude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-11-2004 01:14 PM |
MIX 24 + G4 + Restart | 2relaxed | Pro Tools TDM Systems (Mac) | 2 | 03-26-2004 09:02 PM |
6.1.2 says: "you have to restart your computer" | plevanto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-11-2004 02:37 AM |
