Old 11-23-2011, 10:44 AM
johnscott johnscott is offline
Default (-9128) Running out of CPU power
For some reasons I changed my CPU and motherboard to Intel i7 2600 3.4GHz and ASUS P8Z68V. Reinstall everything and when I am working with my new session I have encountered a new problem which I think is kind of ridiculous...
It says "You are running out of CPU power. Remove some RTAS plugins or increase the CPU usage limit in the playback engine dialog. (-9218)
So I check my setting
512 samples, 8 Possessors, 90% (the highest option)
DAE playback buffer Size level 2, Cache size normal
Plugin streaming buffer level 8
And sure it didn't work, things still happens
So I follow every step to optimize my Windows 7 Ultimate 64bit from
http://avid.custkb.com/avid/app/self...p?DocId=349411
But it still didn't work.
Can anyone help me please??? Thank you.
Thank you again for helping me getting started!~
MBOX2 Mini
Pro Tools LE 8.0.3 (Now updated to 8.0.5)
Windows 7 Ultimate 64bits
Intel i7 2600 3.4GHz CPU and ASUS P8Z68V motherboard
(Previously AMD Athlon X4 630 Processor 2.81 GHz)
16GB of RAM
VST to RTAS adapter, VST plugins, BFD2, Komplete 8 Ultimate
Old 11-24-2011, 12:21 AM
Default Re: (-9128) Running out of CPU power
Hello?
I've read some about RTAS problems and I should learn Reaper and ReWire it to PT and use RTAS plugins and........is it the clue?
Gentlemen please come in and leave some words please, my project is halted so I simply have nothing to do now. Surfing the internet and see if money can solve the problem, which I don't have much. And I read some threads here, RTAS to AXX format, so maybe I have to crossgrade to PT 10? and Reaper ReWire, but I read some synchronize problems?
Oh, please, what can I do?
MBOX2 Mini
16GB of RAM
Old 11-24-2011, 02:14 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Are you running many plug-ins?
Try 3 processors at 95% and watch your CPU meter.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 11-24-2011, 04:42 AM
Yes, I am a heavy plugin user.
In fact I could see no peak from any of the cores in the CPU meter
Now I am trying to combine my PT to Reaper to see if it helps
MBOX2 Mini
16GB of RAM
My new Mac Pro 8 Core is running out of CPU power (-9128)??? Alexvenusa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 02-26-2010 10:08 AM
You're running out of CPU power (-9128) Slap 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-09-2003 09:33 PM
error 9128 running out of CPU power with XP in10shun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-12-2002 02:49 PM
running out of cpu power, error 9128?? Florian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-07-2002 11:15 AM
You're running out of CPU power (-9128) reg2000 Digidesign Hardware & Software 0 11-26-2000 07:29 AM
