Elastic Audio problem
Hi!
I have a problem with ElasticAudio on multible tracks. I recorded a bass guitar, 4 tracks - 2 mics close to the amp, one room mic and one DI box. After recording i successfully time aligned the tracks to avoid phasing problems when i mix the tracks togehter. Now here´s the problem. I wanted to correct some parts of the performance with ElasticAudio. So i grouped the tracks, activated EA added warp markers and corrected parts of the tracks. First i tried it with the monophonic setting. As long as i only activate the warp markers (so i did NOT move them), the bass sounds like before. But when i move one of my markers my tracks start to phase - AND not only inbetween my "edge" warp markers - the whole region phased! So behind the last marker too! So i tried the rythmic algo - it was better, but not good. So i deleted all analyzed warp markers and added manualy warp markers where needed. but it started to phase again... please keep in mind that i don´t mix different takes together, all 4 tracks are from one performance, so (after time aligning) there is no phasing as long as i don´t use EA. Any ideas?
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: Elastic Audio problem
Well, i have never had success with EA on multiple tracks from the same source. Although many people on the forums rave about using it on drums or multiple mics, I just don't hear it. It phases far to much for my tastes. But I have used it on quick drums fills that go by so fast you can't really hear it.
As to your problem, two solutions I would recommend are, using beat detective on the 4 bass tracks (if it's not to far off time, this will sound the best), or blend (mix) and bounce the 4 bass tracks to one and then use mono EA to fix the timing. |
Elastic Audio Problem | LonestarBeatz | Pro Tools 11 | 0 | 07-18-2013 07:56 PM |
elastic audio problem | edwallace | Pro Tools 10 | 1 | 03-01-2013 09:21 AM |
Yet ANOTHER problem, now with elastic audio, I can't be the only one! | farmfresh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-17-2009 07:25 PM |
Problem in Elastic Audio (LE 7.4) | brentrains | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-06-2009 09:24 AM |
Elastic audio PT 8 problem | gracec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-21-2009 08:50 AM |
