Old 07-06-2006, 09:27 AM
Default Bug Report: TL Everyphase Installer
I have found a set of circumstances that will make the installer for the TL Everyphase plug-in useless. Below is a detailed report of my findings.
Problem: If the program ManOpen is decompressed from its distribution .dmg file, the installer noted above is useless.
Reproducible: Yes, 100%
Steps to reproduce:
1. Download the .dmg file for ManOpen from http://www.clindberg.org/projects/ManOpen-2.5.1.dmg.
2. Decompress the disk image.
3. Decompress the .dmg file for the TL Everyphase Installer.
4. Attempt to run the TL Everyphase Installer.
What should happen: The TL Everyphase installer should prompt the user for a password.
What does happen: Apple's Script Editor launches.
Severity: Critical. Once the ManOpen .dmg file has been decompressed, the TL Everyphase installer is not usable. This means that if future updates are distributed using the same type of installer that they will not run on a system that has had the ManOpen .dmg file decompressed on it.
Workaround: None.
System: Quad 2.5GHz G5, 2.5GB RAM, OS X v10.4.6
Contact info for the developer of ManOpen is available at http://www.clindberg.org/projects/ManOpen.html.
The same issue I am reporting here has also been observed with installers from SoundToys. As an end user, I am less interested in whose bug this is to fix and more interested in seeing it fixed. Thank you for your time.
TL Everyphase...>Anyone Try This Plug? tomhartman Pro Tools TDM Systems (Mac) 13 09-12-2017 07:44 PM
Problem with Tl everyphase tamasdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-13-2007 10:22 AM
TL Everyphase Installation Problem manuel27181 Virtual Instruments 0 04-03-2007 08:14 AM
TL Everyphase 1.1.1.5 updater TommyT Pro Tools TDM Systems (Mac) 2 06-15-2006 12:20 PM
TL EveryPhase 1.1 update now available Trillium Lane Labs Pro Tools TDM Systems (Mac) 1 12-18-2003 03:28 PM
