\'Search\' Funtion when loooking for files?
Before i start I would like to congratulate digi on v5.0 , its awesome!
I was just wondering if a search funtion could be added for when PT is asking you to find files when opening a session. When you restore a session from Cdr or mezzo, the links for all the audio files are broken, and if you have a complicated job, with files all over the joint, it is quite hard to locate them. Logic, and Cubase both have 'search' option, where the computer searches itself. This would be great, or at least the option to use 'sherlock' to look yourself. At the moment you need to keep canceling, and then using sherlock. This would be a big help. cheers Mesh PS. while you are fixing that, what say you add stereo audio channels like logic, so you can put stero plug ins on tracks???? |
Select ALL funtion | thenchel | Tips & Tricks | 3 | 10-03-2006 01:16 AM |
where is the tap tempo funtion on protools 6.9??? | carlos santana | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-21-2005 08:09 AM |
Help! Recording Arp funtion output from keyboard to PTLE | J Blazin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-26-2002 08:13 AM |
is there an auto search of audio files feature in PROTOOLS 5? | GROS | Tips & Tricks | 3 | 04-22-2000 03:10 PM |
Funtion of scrub wheel on pro control | Jules | Pro Tools TDM Systems (Mac) | 9 | 01-22-2000 07:21 PM |
