Old 12-24-2020, 09:20 AM
SteveGarman SteveGarman is offline
Default Same old question: Can I run 2020?
I only have one system so I cant afford to experiment and wind up out of business (It's hard enough as it is).
I have a Mid2012 Mac Pro running High Sierra 10.13.6 quite happily with PT 2019.6.0. It's 2 x 2.4 Ghz 6 Core with 32 Gigs of ram and an ATI Radeon HD 5770 with 1024 mb
Is anyone else with this system running 2020? If not, what would it take to upgrade it until it would run it. I like High Sierra. Hope I could keep it and still make the jump to 2020.
Thanks for any advice!
Steve
Old 12-24-2020, 09:30 AM
Default Re: Same old question: Can I run 2020?
Sure, though I'd take it to Mojave if it were me, but otherwise, why not?
http://www.richbreen.com
Old 12-26-2020, 11:36 AM
Is anyone one else with a similar system as mine running 2020.12 with no problems?
Old 12-26-2020, 12:49 PM
tclash tclash is offline
I have a 5,1 Mac Pro running Mojave . . . Just moved to 2020.12 from 2019.something and it runs ok but I've been getting a few more -9173 errors than I was. It also seems to hang a long time when loading UAD plugs during startup.
Old 12-28-2020, 10:54 AM
Thanks for posting your success with 2020.12! I hope I hear some more good news from others.
Steve
Old 12-28-2020, 11:12 AM
Steve
I'm running a similar system except with a single 6 core 3.46 GHz cpu and 48 gig ram in OSX 10.13.6 and it's running PT 2020.11 no problem. I haven't moved to 2020.12 as I'm in the middle of a commission. Keep in mind if you want to go beyond OSX 10.13.6 you're going to need a Metal compatible video card. There's a few that are available that'll work but if said card is not flashed for a Mac you won't see the traditional boot screen but once booted they work fine.
Old 12-28-2020, 11:29 AM
wwittman wwittman is offline
Curious as to why you’d say that
Quite a few people seem to think High Sierra was less problematic.
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
Carl Lie Carl Lie is offline
I'm on a 5,1 with High Sierra and it's working fine. 12 cores with 48 GB Ram.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 12-28-2020, 01:36 PM
Panacci Panacci is offline
I am running latest PT on High Sierra 13.6. Working great here. Install it with your older version of PT. In applications rename the old version then install the new version and check it out.
2009,2012 8 Core Mac 5.1, (32 gigs Ram), MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.3 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com
Old 12-29-2020, 08:21 AM
My experience is the opposite - Mojave very stable on 4 machines I'm running here - plus it's just closer to newer OS so less pain later and fewer compatibility issues. That said, High Sierra seems to work fine on a couple clients' machines.
Question about PT version 2020.3/Windows 10 - Notable bugs? take77 Pro Tools 2020 2 11-12-2020 09:23 AM
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? derrickhou macOS 4 07-26-2020 07:46 AM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
Plug-ins/PT 2019 (2020) Installation Question TDTPost Pro Tools 2019 4 03-20-2020 02:25 PM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
