Re: Pro Tools 10HD&11HD not recognizing HDX connected Digidesign 192 i/o
do i need a seperate driver for the 192 i/o?
Have you cleared the preference file?
I remember a problem with adding 888s that they wouldn't show up without clearing the file to trigger a full rescan of the interfaces attached
The HD driver should be all you need.
I got the 192 working!
I realized, that the input card configuration of my unit was different than suggested in the manual. - So i changed it to Slot1 (Upper Left) Analog Inputs Slot2 (Lower Left) Analog Outputs Slot3 (Upper Right) Digital Slot4 (Lower Right) Analog Inputs - I also trashed the preferences. - I double checked that both units have their Digilink cable attatched to the Primary Digilink Port (192 I/O Digilink Cable goes to secondary Port on HD I/O or HDX Port two, both is possible) After the change and a restart, Digitest AND Pro Tools recognized both the HD I/O and the 192 I/O. Thank you all for your inputs! |
Have you tried this with PT12?
No Problems here with HDX with 3x 192 in 4.1/5.1 with PT10/11/12 HD. But 192 configuration like above... Best |
I upgraded 4.1 to 5.1 with Pindelski in Arizona. Firmware and all ram updated. All works fine and faster than Trash can, will be going to HDX card and HDX sync with 192. will get back to you...
Dick Maitland C.A.S. |
Upgrade from PT 10HD to PT 11HD? (bought 10HD on eBay) | Concept Chelia | Pro Tools 10 | 7 | 09-12-2014 04:01 AM |
PT 11HD still shipping with PT 10HD? | jrmintz | macOS | 10 | 03-09-2014 12:12 PM |
96K session in 10HD with UAD2plugs, will not run on 11HD | ericgreedy | Pro Tools 11 | 4 | 12-19-2013 07:42 AM |
Can't import FCP OMF in 11HD, but can in 10HD | Arno Peeters | Pro Tools 11 | 1 | 10-30-2013 06:24 AM |
Upgrading from 9HD to 10HD/11HD | simonyeah | Pro Tools 11 | 6 | 09-30-2013 02:10 PM |
