Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 03-24-2015, 05:56 AM
christophersad christophersad is offline
Default PT first and eleven rack.
quick question,will protool first be fully compatible with 11r?and will it hqave the so loved "mute direct monitoring" on the 11r option?
Old 03-25-2015, 12:19 PM
Default Re: PT first and eleven rack.
I have no idea, but if I were a betting man, I would not hold much hope. Mostly because, since Eleven Rack is delivered with the full version of Pro Tools, I don't know if it will work at all with PT First(hope I am wrong)
Old 03-25-2015, 03:03 PM
Benoni's Avatar
Benoni Benoni is offline
Yes. You can use First with any interface you want that is ASIO/CoreAudio
http://www.avid.com/US/products/pro-...mparison-table
Old 04-01-2015, 01:45 PM
thank you Brian, do you also know if the "mute direct monitoring" option for the 11r is included?
Old 04-01-2015, 01:59 PM
Nobody here knows for sure, or if they do they likely won't say. But Avid would have to really go out of their way to break this, and what you are asking about has worked with every version of Pro Tools in the past. So Avid is unlikely going to deliberately break this in First. But as with the many other questions about First you'll have to wait and try it to see for sure.
Old 04-13-2015, 02:01 PM
jeffro's Avatar
jeffro jeffro is offline
Just tested on my Mac system, and it does mute when opening a project.
Old 04-13-2015, 02:22 PM
Well somebody here knows for sure, and they did say
Old 04-15-2015, 03:14 PM
many thanks guys,jeffro can you enable and disable the monitoring at will?
Old 04-18-2015, 09:27 AM
You do know that no version of Pro Tools has ever provided that...
Old 04-18-2015, 02:25 PM
jeffro's Avatar
Nope. It mutes when you open a session, and 'unmutes' when you rec enable a track/while recording.
Differences Between Eleven Rack & Eleven Plugin Becharax Eleven Rack 15 10-16-2015 06:07 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Some experimental tracks using Eleven rack and Eleven RTAS kittybite Eleven Rack 4 06-18-2013 12:18 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
