Old 08-13-2014, 11:22 AM
jgiannis jgiannis is offline
Default Moves clips vertically without shifting horizontally
Oddly enough, after 10 minutes of searching, I can't find an answer to this very basic question.
I am working in PT10, Mac.
I need to move clips from one track to another (i.e., vertical move), without shifting the timing of the track left or right (i.e., without horizontal moves). The timing needs to remain absolutely identical to what it was in the original track.
Currently, I am using my mouse to click each clip, one by one. Keyboard focus is enabled. I then simply drag up or down to the desired track.
Ideally, I want to continue working this way, except I want to be able to hold a button while dragging-vertically to prevent any shifting-horizontally.
Any ideas?
Old 08-13-2014, 11:42 AM
Drew Mazurek's Avatar
Default Re: Moves clips vertically without shifting horizontally
Control key is your friend while using the Grabber.
Or copy, then move up/down with the P or ; key then paste.
www.drewmazurek.com
Pro Tools moves clips after stopped recording Maximumpower macOS 3 07-10-2012 12:53 AM
Zoom Vertically like R T zooms Horizontally claesbjo Pro Tools 9 5 06-24-2011 02:27 PM
D-Control Range Selection both Horizontally and Vertically moofie ICON & C|24 7 08-18-2009 12:49 PM
external drive - horizontally, vertically? Andi R 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-10-2005 06:56 PM
Protools shifting audio clips??? wagged Post - Surround - Video 2 04-01-2005 09:35 AM
