Reverb One "Bug" found in PT 11
Just Downloaded and installed Reverb One in PT 11.
Put it on a stereo instrument tack. With the default reverb I can tweak the mix knob between wet and dry, BUT when I change to another preset and adjust the mix knob nothing happens. It stays on 100% wet. Anyone having same issues? |
Re: Reverb One "Bug" found in PT 11
Maybe they intended it to only be used on an Aux buss?
the mix knob resets with every preset... SO elfin annoying...
OXFORD reverb had a Mix lock... for auditioning presets when inserted on a track rather than an aux... but yes with reverb one i just set up on an aux and check preset there... even if i want it just on the track itself... this way its just easier to deal with based on how reverb one works. I really like the reverb itself though so its worth getting it set up to bet utilize it
Jay-J System MacPro 12 Core • 24 G Ram • 10.12.6 PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified 4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card • Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
But the Mix knob Don't work at all. even when I put it all dry at 0% it is still 100% wet. It has to be some kind of bug. It is unusable on tracks.
I run PT HD Native Thunderbolt 11.2.1 on Macbook Pro , Mavericks 10.9.4 Maybe Avid tech support can chime in on this? |
You did notice the little button above the mix fader, right?
yeah that
even though its a stupid workflow. seems silly... should be that if I grab the mix knob the WET button deactivates to accommodate. easy, simple work flow.. If slider moved - de activate wet. done. See thats practically computer code right there.. you are welcome avid. ;-) Anyway.... check the wet button... the UI isn't really dope either as its hard to really tell if its ON or OFF.
thanks so much for helping out:) appreciate it |
"The files for installation requirement Pace License Support could not be found..." | KingDingbat | Pro Tools 10 | 4 | 02-11-2019 06:12 AM |
Found a cure for "Access Violation" error! | Aargl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-09-2013 06:34 AM |
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." | Elias Stiza | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2012 07:06 PM |
Mbox mini installation problem - "Hardware Not Found" | tinsoldierman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-18-2010 03:06 AM |
Digi CoreAudio says "Not connected (HW not found)" + Kontakt 4.0.5 problem | stevolution | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-04-2010 09:48 PM |
