#111
Re: 8.0.4 is out.
Same here with 002R and blinking light when it stopped working. After a few reboots it started to work but the tracks that I recorded previous was playing back a click early. I think its time to update my 002r real soon.
#112
Re: 8.0.4 is out.
Hey guys, I have a question(excuse my ignorance).
I was never able to get version 8.03 running on my 64bit Windows 7 laptop. Kept getting blue screens and crashes during installation process. So how do I get the officially compatible windows 7 upgrade(8.04) on my system?? I'm so confused and scared, lol. Please help! |
#113
Re: 8.0.4 is out.
To start, turn off or unplug the interface. Don't hot swap. Uninstall the 8.0.4 driver if you have it installed. Restart and install the new 8.0.4 update following the instructions on screen. Pray. See what happens and report back.
#114
Re: 8.0.4 is out.
8.0.4b driver that is. It will PROBABLY show up in Programs and Features as Version 8.0.3, but that is the correct one to uninstall.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
#115
Re: 8.0.4 is out.
If you got to the speaker icon in your system tray. Right Click the icon. Choose PLAYBACK Devices. Do you see the 002 Listed as an option. If so. Make it the Default Audio device and see if you can play Windows Media Player through it or something like Youtube ect... IF if works. Go through the tray and DISABLE everything that is showing up for the 002, ie. IN 1-2, IN 3-4, IN SPDIF, then go to Recording Devices and do the same, disable everything 002. Launch PT with Run As Admin, what happens?
#116
Re: 8.0.4 is out.
Cubase 5.5.1 :: Ableton Live 7.0.18 :: Pro Tools M-Powered 8.0.4 Windows XP Home SP3 :: Gigabyte GA-EP45-DS3R :: Core 2 Quad Q6600 2.4GHz :: 4GB DDR2-800 Mac OS X Leopard 10.6.4 :: Macbook Pro 2.16GHz :: 3GB DDR2-667 Access Virus TI Polar :: M-Audio Profire 2626 :: UAD-2 Duo :: UAD-1 |
#117
Re: 8.0.4 is out.
Works like a charm!
#118
Re: 8.0.4 is out.
**Edit - After running some tests, this appears to be a hardware status indicator bug. Once a firewire communication is established for the first time and then the app closed, the blinking stops and behaves as it normally should in previous versions of Pro Tools, which is completely off or solid green. The incorrect status indicator doesn't appear to effect anything else other than communicating an incorrect state. Avid will have to be made aware of this. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#119
Re: 8.0.4 is out.
ahhh 8.04 sucks that it the last version for windows xp but being that it's ready 4 win 7 i guess it time to upgrade my gigabyte mother board to one that holds more ram.
Melthoven/Meltoast DIGI 003 RACK/i7 920, GA-EX58-UD3R, 6gb OCZ Platinum ddr3 1600, 2x 640gb WD Caviar Black, WA Black 1 tera Windows 7 ultimate PT 12.5 Www.Facebook.com/melthovenbeats |
#120
Re: 8.0.4 is out.
This is a good thing actually. Supporting 7 operating systems, which they are currently doing, is not good for development at all and quite the waste of resources. Soon they'll be able to just focus on two operating systems only. It will benefit us all in the end. W7 started off with very bad performance when it came to running PT initially. Avid Audio did their job and optimized PT for W7 quite well out of the gates, which is a first, as in the past we took quite the performance hits as we moved on to new Operating Systems and higher versions of Pro Tools. Instead of advancing like we should've been, we were going back in time taking performance hits. There's still some needed polishing here and there but they matched the performance in XP, and far surpassed that of Vista. We can bid XP a good farewell knowing we're moving on to something better. It had a pretty good run with Pro Tools. Farewell to XP, good riddance Vista, and hello to Windows 7 64. Shane
