Old 06-04-2019, 05:08 AM
Felix Andriessens Felix Andriessens is offline
Default Field Recorder Matching Channels Resulting in Wrong Channel Name
I just received an AAF from premiere which opened ok. Its not the first Premiere AAF I'm working with and I am used to having all field recorder tracks channel names set to "MixL" (or to whatever the field recordists set their first tracks name to) by default and then to manually match each clip I want to have with the correct channel name on. (Just in case that wasn't clear: I receive a timeline with lets say six tracks of a recording, all channel names showing "MixL"; if I want to make sure I really selected the boom-track, I right-click one of the tracks, select the track named "boom" from the field recorder match menu, and this way work my way through a session.)
My problem today is that the AAF/session I received not only shows the usual "all channels named the same" phenomenon, but additionally does not show any different channel names for the matching field recorder tracks it offered. They also all show "MixL" only under channel name. I am linking to the original production sound files that show correct channel names in Soundminer, WaveAgent etc. Is there any way to change this behaviour?
Working on Ultimate 2018-7 right now.
Thanks!
Old 06-05-2019, 08:14 AM
Default Re: Field Recorder Matching Channels Resulting in Wrong Channel Name
Ultimate 2019-5: no change.
Old 06-05-2019, 10:54 AM
Reckless Erik Reckless Erik is offline
One work around would be to conform one channel of the polywav for each clip and then expand that track to get the rest (with the metadata intact)
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 06-05-2019, 11:47 AM
Yes, thanks, I was about to go the Ediload when fiddling again with the match criteria brought up the right files. I think it must have been a strange mixture of an 2018-7-bug and match-criteria-problems. I'm good now.
HTML code is On
Matching field recorder delay kirka.sainio Post - Surround - Video 0 05-03-2017 10:59 PM
Field recorder matching issues mr.armadillo Post - Surround - Video 6 09-12-2013 04:07 PM
Field Recorder Matching issue feakerboo Post - Surround - Video 3 04-25-2012 04:37 PM
PT 10 with CPT: Field Recorder Matching? Svante Biörnstad macOS 4 12-13-2011 02:45 AM
Like the new Field Recorder matching in options in 9.02! Pete Gates Post - Surround - Video 0 03-10-2011 01:39 AM
