Old 04-25-2019, 03:26 AM
anotherone anotherone is offline
Default i9-8950HK Compatibility
Hi there
I need to make a decision on which MacBook Pro to buy.
Is there anyone with some experience with the maxed out MacBook Pro 2018? Can I expect i9-8950HK to be supported in ProTools 2019? Or is it safer to go for the i7? I already made the mistake once some time ago to choose the fastest CPU with a Mac that was never supported by ProTools and that performed worse than my older computer.
I am aware of the ProTools 2018 / Mojave situation.
Many thanks
Old 04-25-2019, 04:05 AM
Meads Meads is offline
Default Re: i9-8950HK Compatibility
Originally Posted by anotherone View Post
Hi there
Many thanks
Andri
The issue is cooling. The slim Macbook isn't able to keep temperatures down which causes the CPU to throttle. It hardly every reaches its speced turbo clock. Many tests show it performs even worse than the i7 in certain workload situations. From the info I gathered when looking into it, people recommend the i7 over the i9. Plenty of videos on YouTube about that topic.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 12-07-2019, 11:25 AM
MixerGuy MixerGuy is offline
any news about this now? in Dec 2019
thanks
Old 12-08-2019, 08:48 AM
thanks
I ended up going with the i7-8850H because of the issues mentioned above and I'm very happy with it so far. My MacBook Pro handles excessive mix sessions with >120 Tracks and lots of CPU heavy plugins as well as a lot of virtual instruments with ease.
I think they kind of fixed the heat issue with the i9-8950 by just throttling it's performance. The newer 2019 model is supposed to handle this better, but I can't tell you more about this than what they say in their advertisements. If I had to make a buying decision right now, I would go with the 16" 2019 model for sure, but as I said, I can't complain right now about my 2018 model.
OS Compatibility cvanscott Windows 1 12-06-2013 05:09 PM
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade benosullivan Pro Tools 9 2 11-17-2010 11:05 AM
Compatibility pablo_r Pro Tools TDM Systems (Win) 0 07-03-2010 08:07 PM
XP compatibility TheJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-05-2001 03:48 PM
Compatibility PC/MAC Nikitas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-29-2001 08:49 AM
