Re: DAE Error -9019 & -9031 since PT 8.0.3
Can you guys do something for me - after you experience the error, quit Pro Tools as soon as possible after it, then send me your LogFiles folder from inside your Pro Tools folder. Zip it up and send it to: vi [at] digidesign [dot] com. Put the thread number (265212) and '9031' in the subject of the message.
dc |
I'm getting these errors right now with a midi-only session, controlling the PLAY EastWest orchestral plugin.
Never seen it before today. Recently updated to 8.0.3. Let me know how I can help. Thanks |
2.66 Ghz i5 iMac, 4Gb Ram, 1 TB SATA (Partitioned), Mac OS 10.6.2, M-Powered 8.0.3cs1, Profire 610. Thanks. |
This error on Mac is also caused by incorrect drive format. I would recommend backing up your audio/video drives and erasing them using the Disk Utility, then copy the data back and test again. |
thanks reichman!
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache |
Do you think that it may be because I'm recording to a partition (dedicated to audio) of the internal drive? If so, would a USB external drive be a solution? Since I'm on an iMac there's only one firewire 800 port. I have read successful stories from guys using USB drive as an alternative but I'm not sure. |
Just happened to me again on Saturday. This time when it happened, I was changing the output of a channel.
Digi, I've zipped and sent my log file using the directions posted earlier ( I think it was on pg 1 of this thread)
one more thing - I had trashed prefs about 2 hrs before this crash.
Please see the General Troubleshooting thread for more details. With an iMac that has only one FW800 port, get a FW800 to FW400 cable to connect to your drives and interface. |
Dae error 9019/9031 | shaunandrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 04-10-2011 12:38 PM |
Error -9019 and -9031 | henrikas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-05-2011 09:34 AM |
Structure v1.1 error 9031 and 9019 | insanesounds | Virtual Instruments | 62 | 03-16-2011 03:19 AM |
err -9019, -9031 greetings to Digidesign. | sotger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-03-2010 06:23 AM |
DAE Error 9031, 9019, 9073 on Pro tools M-powered | rico1234 | Pro Tools M-Powered (Win) | 0 | 12-12-2009 12:28 PM |
