Re: OS Alternatives now that Mountain Lion Support Ended?
Yes, do a clean install of Sierra (not upgrade, but erase hard drive and start fresh) and then install PT 12.6.1
EDIT: Found the link to renew the upgrade plan for $299... seems pretty steep. Can I run 12.4 with Sierra? EDIT2: I tested out Sierra quickly with 12.4 and a few of my projects. Everything works out perfectly fine. Actually impressed with the numbers I was looking at. I didn't even do a clean install. I just upgraded my El Capitan partition to Sierra and it brought in PT12.4. Granted, most of my projects are 6-10 tracks with 2-3 plugins per track each and only Addictive Drums 2 as a VI. Even so, the CPU meter was at 8%. I think I'll stick with 12.4 unless there's a compelling reason to pay $300 for the upgrade. FYI I'm running the following: MacBook Pro 9,1 with an OWC 3G SSD 2.6Ghz i7, 8GB RAM OS 10.12 Sierra Digi 003 OWC FW400 external HDD
15" MacBook Pro 9,1 mid-2012 15in 2.6HGz i7, 16GB RAM, OS 10.12.1 | OWC 320GB FW400 7200rpm Digi 003 | PT 12.4 Last edited by Alexrkstr; 11-30-2016 at 04:31 PM. |
Just updated a few more things.... everything is running very smoothly with the existing install (not a clean install), but I will wipe this drive and install the 6G when I receive it. That should help as well. I think I may have a super machine now that I'm upgrading RAM to 16 and SSD to a 6G. Just hope 12.4 is good enough for what I need.
15" MacBook Pro 9,1 mid-2012 15in 2.6HGz i7, 16GB RAM, OS 10.12.1 | OWC 320GB FW400 7200rpm Digi 003 | PT 12.4 |
You can, but it won't be supported. Your mileage may vary. First release done with Sierra in mind was/is the 12.6.1 that just got out
Lion to mountain lion upgrade file needed, anyone? | Audioartist | macOS | 0 | 09-26-2015 08:46 AM |
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION | DESVED | Pro Tools HDX & HD Native Systems (Mac) | 2 | 05-21-2013 03:18 PM |
lion -> mountain lion question | grant howarth | macOS | 3 | 05-01-2013 01:24 PM |
Would you go from Snow Leopard to Lion (not Mountain Lion) if you could? | EricWillhelm | macOS | 9 | 01-11-2013 10:55 AM |
Downgrade from Mountain Lion to Lion | The golfer | macOS | 7 | 11-14-2012 05:53 AM |
