Old 05-07-2014, 01:46 AM
Raoul23 Raoul23 is offline
Default Control 24
Hi Guys
Could anyone shed some light on what to look for when buying a 2nd hand Control 24 I'm after one to use with my TDM rig Pro Tools 10HD
Do these have common issue/faults
Thanks Raoul
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 06-03-2014, 03:12 PM
scotsman scotsman is offline
Default Re: Control 24
Hi Raoul,
Check that all the faders move, the switches all work and the monitor section work. Much has been said about the power supply but once replaced the new supplies are good but there is sometimes an issue with cable connections which just need a clean and reseat then it is all good.
So it is important to see the unit powered up and at least put through a "Vegas" test demo which switches/cycles all the LEDs and moves the faders. Best to have it connected to PTs and see it working and passing audio.
Good luck, mine has work very well for 10 years
Cheers
Scotsman
Avid Digidesign Control|24 and Sterling Modular Desk Console for Control 24-Separate relaxo Buy & Sell 3 09-05-2013 08:05 AM
How to control plugins applied to audio files with Artist Control ozu Artist Series 3 04-01-2013 03:36 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 01:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 08:03 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 07:12 AM
