Old 05-10-2006, 07:03 AM
crizdee's Avatar
crizdee crizdee is offline
Default pro tools stops recording then error message
I've been trying to record a long 5 hour session, but first attempt it stopped after 64 minutes! and yes i have got unlimited recording allocation set!
Second attempt about 40 minutes in it stopped again and i get the message "assertion in CneoReferable,h,line 88" and any attempt to click ok on this serror messsge and it just kept coming back? untill i had to force quit PT.
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-10-2006, 07:14 AM
jeremyroberts jeremyroberts is offline
Default Re: pro tools stops recording then error message
Chris,
Any chance you are hitting the 2GB limit on any single file?
--Jeremy
Old 05-10-2006, 08:02 AM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
Are you recording from analog or digital sources? Can you provide all the details of your system including the session parameters?
Avid Audio Tech Support
Support FAQ
Old 05-10-2006, 09:41 AM
crizdee's Avatar
Recording digitally from Adat HD24 6x mono tracks bussed to 1 record track!
48k 24bit
word clock sync from the 192 to HD24 and 192 the master
hw buffer 512
rtas 2 processors
cpu 85%
long DLY
DAE level 2
HD3 accel C24 G5 dual 2gig 4.5g ram 145gig free available on audio drive SATA
Mac OS 10.4.6 just recently updated to 4.6 from 4.5 using the combo updater!!
waves lin EQ x5
Eventide EQ45
waves L1 limiter
The longest it got to was 148 minutes @ 1.2 gig data (Thanks for the thought Jeremy )
Took 3 attempts but i got it finished finally
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-16-2006, 09:51 AM
What version of Pro Tools are you running?
Support FAQ
Old 05-16-2006, 10:55 AM
crizdee's Avatar
Sorry forgot the most important but!! 7.1cs7
Had this again on a different session, again when record a long file 80mins.
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-29-2006, 01:23 AM
Asp Asp is offline
Having the exact same problem. Did any come up with a solution. Not to mention the Digidesign staff?
Old 09-29-2006, 07:20 AM
crizdee's Avatar
Hi Asp,
You'll need to give us you're system details, what mac are you on and what ver OS and which PT system do you have and what are all your settings set to etc. give as much information as possible for others to be able to help you.
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-30-2006, 03:08 AM
Scott Goldberg Scott Goldberg is offline
Chris,
Any chance that the culprit is the HD external recorder? Or would it be worth it to try an analog transfer instead just ti see if that works? Just stabbing in the dark here Chris sorry. What about the Mac? I know you keep your systems in good shape but is is possible that there is something funky going on with your system? Maybe a corruption occurred? I know, just stabbin' in the dark here, good luck!
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Old 01-04-2007, 02:14 AM
Asp Asp is offline
OK
My system is a G5 Dual 2.7 Ghz/2.5 GB RAM PowerMac with 10.4.8, PT 7.1 cs10 and a 192 I/O synced up to a Sync I/O with an external word clock. Hard drive is a Lacie d2 250 GB. Have also tried the Digidesign OS X guidelines without any solution to the problem.
HELP NEEDED!!! Pro Tools Error message when recording..Easy Fix? Osser macOS 5 11-04-2013 05:57 AM
Pro Tools HD Stops Recording or Bouncing Randomly Mike Stosich Pro Tools TDM Systems (Win) 6 10-21-2010 12:43 PM
Song Stops every time at :57 - 9128 error message dts.music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-13-2007 01:16 PM
wierd error message stops me saving etc. gfunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-11-2007 12:15 PM
Pro Tools stops during recording- usb error Manfur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-30-2004 10:57 AM
