#501
Re: Play/Pause issue driving me nuts...
2. It will eventually start to play, but sometimes PT forgets to include some VIs, i.e. Midi tracks don't play. Click track has a delay. 3. 002R
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
#502
2. It does usually play eventually. Don't remember any error codes. Sometimes it plays after only a few seconds and then I get the MIDI note "explosion" as described by Banana. In that case, the click is usually off, too. 3. 002R
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#503
For what its worth, my 002R clocked to Big Ben, pro tools 7.1 audio dedicated Core 2 duo with 4gig's ram optimized to the max, will start if I bang on the space bar really hard 7 or 8 times, but then I realized that the number of times I pressed it had nothing to do with whether play occurred. If I press play one time, play will eventually occur some time in the future. I've gone through two keyboards banging on the thing to get pro tools to play. I opened the window behind the studio once and threw a keyboard into the bayou because I got so pissed off. I realized I had made a mistake though. What I should have thrown was the 002R.
The studio lost a seriously good paying client because of this defect. All I could say was I am sorry.
Dean Guidry Attorney at Law Lafayette, LA Collections, Personal Injury, Entertainment Law myspace.com/studio89rocks Last edited by deanguidry; 06-18-2009 at 10:19 AM. Reason: typo correction |
#504
You could have taken me out and dusted me down. I managed to get in three hours of recording overdubs and mixing without a single blip. This was a first time ever without the play/pause/plague hitting this particular session. When I was done, I closed down Pro Tools so that I could do some topping and tailing on the mix in Soundforge. Then I open up Pro Tools again, go to the same toon (without having a look at the playback engine page, and wham, the PPP is there right from the start. It went like this. First recording take, nada. The record button flashes once, the play button flashes once, the stop button flashes once, in sequence, then I sit around twiddling my thumbs for seven (just to be sure) minutes while nothing happens. Second attempt. Same thing. I got a take going on the 3rd, 4th and 5th attempt. Sixth attempt. Failed. But this time only the record button gives a flash. The play and stop buttons are inert. It doesn’t take off after twiddling for eight (just to be doubly sure) minutes. I get a take going on 7th & 8th attempt. The 9th fails. Record, play and stop all flash once in sequence. There were no error messages during this session. I have an 003 mixer. I tried re-starting Pro Tools a few more times, sometimes by opening the playback engine first and sometimes not. I get PPP all the time. No error messages. Go figure.
STUDIO RIG: Dual Core CPU, 6700 @ 2.66GHz, 2.00GB RAM, NEC DVD RW ND-4571A, Windows XP Home, 003 Mixer, PTLE 7.4cs10 MOBILE RIG: Dual Core CPU, T9300 @ 2.50GHz, 3.00GB RAM, TSST CDDVDW SN-SO82H, Windows XP Home, MBox 2 Pro, PTLE 7.4cs10 |
#505
PS - My wife is from Baton Rouge. I think she once opened up the window and tried to throw me out into the bayou.... |
#506
Here are the fixes for the latest Reaper update released June 15, 2009:
Dean Guidry Attorney at Law Lafayette, LA Collections, Personal Injury, Entertainment Law myspace.com/studio89rocks |
#507
[QUOTE=PS - My wife is from Baton Rouge. I think she once opened up the window and tried to throw me out into the bayou.... [/QUOTE]
Cajun wife, I suppose....
#508
digi = large, inertial and resistant |
#509
The current Digi bug reporting and handling system needs a serious evaluation and overhaul cuz the noobie DAWs are very quickly starting to DAWminate. The reported play/pause issue goes as far back as the PT 6.x era which has been literally years. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#510
Pro Tools 11 Play-Pause Issue | ProdGawd | Windows | 7 | 12-12-2013 05:22 PM |
PLAY / PAUSE - Issue ... Once More !!! | Zergei | Pro Tools M-Powered (Win) | 2 | 12-27-2009 11:50 AM |
Some info on the Play Pause Issue | Fastermouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-31-2009 05:18 PM |
Play/Pause Issue Resolved - Maybe? Try This. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 167 | 06-20-2009 08:42 PM |
cursor issue driving me nuts!! | stevesound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-12-2006 03:21 AM |
