sinking tape to protools
can any one tell me how i can sink tape to protools so that i can do a 24 track transfer without losing the tempo on the second pass??
any help is welcome daul 2 GIG G5, 2 150 hard drives 1 GIG memory 02r with adat
JAMAICAN I IS 2008 2009 and 2010 Mac Pro 8 core with 64 GIG memory with 9 terabyte of hard drive space blue ray player HDX 1, 2 16X16 interfaces sync I/O. |
Re: sinking tape to protools
would that be with a kitchen sink or a bathroom sink ?
Search the DUC for the word SYNCH.
Rail
wise guy eh? so i used the wrong term, pardon for living.
This may get confusing but here goes!
Two groups, A and B. Take your tracks for group A, then your tracks for group B, but take a duplicate of a track from group A with group B, this is your "sync track". Once finished with both, move your two sync tracks so that the track in A is at the bottom for group A, and the matching track in B, is at the top of B (or just below it's matching track) Now, use "tab to transients" to find the first major transient on Sync track A, and CMD E to cut. Do the same to Sync track B (make sure its the same transient!!!). Next, trim all the tracks above sync track A past sync track A's start point and trim all the tracks below sync track B past sync track B's start point. Next, go into Grid mode (if not already there). Use your hand tool to select sync track A. Hold shift and also select all the above tracks. Move them to any grid mark. Now do the same with sync B and it's tracks. Double check you sync by zooming in to the front of your sync tracks and making sure the waveforms match down to the sample. Disable and hide one sync track, playback and done! |
Search using the term: +DTP +Rail +synch
Set the search to the last 5 years. You should find loads of threads where I've answered this. Rail
G5 2 daul 2 GIG 1GIG memory ADAT and 002R 6.4 two 150 GIG hard Drive
i am. what i would like is to find a cheap smpte writer/ reader thank for the info. Robert
+DTP +Rail +synch You set the search length to 5 Years You set it to search all the forums If you can't accomplish this, the answers you would find won't help. Rail
Thanks for the vote of confidence, but i did it at least six times all i got was cannot procced, but tell you what since all this is new to me why don't you try it nad tell me what i am doing wrong??? thanks robert
Recording to 2" tape & Syncing to protools | eledu | Pro Tools TDM Systems (Mac) | 4 | 02-12-2008 10:42 PM |
tape to protools Sync | 2224 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 09-09-2004 05:34 PM |
1/2 inch 8 ch tape to protools | fredsparky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-17-2004 04:03 PM |
ProTools and Multitrack tape | gregfrey | Pro Tools TDM Systems (Mac) | 0 | 03-14-2003 07:42 PM |
Protools VS SSL , Neves, Tape analog | LH | Pro Tools TDM Systems (Mac) | 13 | 10-27-2001 07:29 PM |
